what steps are those?
They've been very solid. I originally added clearbra about 10" up the rocker to the first body line since I'm not running mud flaps. The boards have worked great for protection. Probably don't need the clearbra.
good idea. here where i live, needs mud flaps,
Here's mine, Rough Country 2". There is still about .75" of rake.00bd718694c413d7519fbc6948d5efaf.jpg1cce9995d810bff60ec5b722c940a1b8.jpg
2" with 285/55 ko2s
Will go higher next time
You have rear blocks? Looks good
Thanks - no additional rear blocks. It's perfectly level without them. Here's a pic on flat surface (before installing steps) post-155890-150172678652_thumb.jpg
2.5 in RC Leveling Kit
RC Step Bars
Is there any ride or performance or wear difference between the 2.5" level kits like Motofab that load one side of the coil vs RC which does 2" on one side and .5 on the other?
Was a member of this board several years ago then made the decision in 2013 to sell my 2008 Chevy LT Crew Cab. Kinda drifted away from the forums for a few years. I got back into the truck market right after the first of the year and signed back up in March and lurked and researched for couple months. Picked this beauty up mid June and just finished up my mods. Here she is...
2017 GMC Sierra SLT Premium Plus
6.2 L engine
2.5" RCX level (front & back)
20 x 9 x 1mm Fuel Maverick
295/55r20 Nitto Ridge Grappler
b732de7aa1c0941a63aea53d0e43a3c4.jpg8fc3f00e1ea9d875059029574da96f6c.jpg4fc04991e0b38877121ec6bde710d1b3.jpgcc653cdbb391ebdcf45627d446c81758.jpge16d0f37667c5c615ea31d6758dc9720.jpg
  • Like 4
6.2 L engine
Great looking truck man, I think I'm gonna go the same route except getting Toyo RTs.
Any rubbing?
Any rubbing?
Thanks! Just barely rubbed at full lock at the bottom rear of the wheel well liner where it bumps out. Little bit of trimming and no more rub. I cut away just enough to remove most of that molded hump. Can't tell it's been trimmed.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 451 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
