On 12/7/2017 at 4:27 PM, rudyb said:
Wth... that's awesome. I called a shop here in OKC yesterday and they quoted me $370. Looks like I need to do some more shopping.
i got mine done at JOPAC in midwest city for $225 last year...i think normally it is $275, but he gave me a deal, not sure...that included an alignment from sears, down the road from them.  I have been very pleased.
14 hours ago, Sierra1500mm said:
Got new tires put on. 35x11.50 Trail Grapplers. Truck has a 2.5 leveling kit by Rough Country. Also got front and rear replacement bumpers by Ranch Hand installed.
How much rub do you have with that tire size?
It rubs but not too bad. I️ had to trim some of the fender liner. It doesn’t affect driving off-road too bad either.
Temporarily removed toolbox. Looks great without it. Really can see the new stance. Looks like it still has a bit of rake.
2018 GMC Sierra SLT / 2.5" Top Gun Leveling Kit / 275/65-20 Nitto Ridge Grapplers
Any issues with fit with the 275/65 Ridge Grapplers?  I swore I'd never go Nitto again after I blew through two sets of Terra Grapplers way too quickly on previous rides, but I keep hearing fantastic things about the RGs.
7 hours ago, Michael Sharp said:
Ag96, Love that set up. Any rub? Did you do a block in the back?
I rubbed at full lock on the inner wheel liner.   Zip tied them back and no issues at all now.
I just have the 2.5" front level with no rear block.  Still about 0.5" of rake but its not noticeable.
No issues other than the wheel liner rub mentioned above with the stock wheels.  Its pretty common once you go to 34s with a level.
It's my first set of Nittos and only 1500 miles on them so far.  I love the way they ride, performance in the rain, and quietness with such aggressive looking tires.  I had TOYO AT2s on my 2014 and they are just as quiet.  Curious to see how they do on mileage.
What is the exact tire size please. any rubbing? Also what do you think of the performance of the programmer and are you worried about voiding the warranty because of the programmer.
Just got a 2.5” RC leveling kit. Truck sits 39” / 39.5”. I’m getting a new set of 20” wheels and 33x12.5R20 Open Country M/Ts put on it tomorrow morning! I’ll submit another picture once it’s done.
Just put the new shoes on her! There’s a SLIGHT rub at full turn.
Edited by Jason Halley
On 12/19/2017 at 9:53 PM, ZachH06 said:
My 2014 with 2" rough country leveling kit on 33x12.50's. Love it so far.73f2d7122418c8b50e7ffc0d3402624b.jpgbce6c0b8b9f65ea68ed009700c51a4c7.jpg451b8f8aef4cff01b351f208007410fc.jpg
Sent from my SM-G935V using Tapatalk
Offset on the wheels? -24? Looks good. Rub at all? I am about to do the rcx 2” and haven’t decided on wheels/tires.
Not sure on the offset. Just traded for these. I dont think its as much as -24. Only hear rubbing in reverse at one certain point while turning, but no rub at full turn.
Ahhh. They look to have a decent lip. I really like em. Think they are perfect. Do you have a picture looking down the side of the truck to show how much they stick outside the fenders?
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 536 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
