Yes, it is. No clunks at all. They are stock Z71 tires. 265/65/18
Cool good to know. Might do the same to tide me over until I can afford coilovers
You would love it :)
Just now, math_10silverado said:
can you tell me what wheel are those?? they look very good nice truck btw
These are Volk Racing TE37 large PCD wheels. For sale BTW ;)
wow wait those are pretty rare!! i knew they looked like te37 well i think im to far away to get them from you...
People looked at the wheels all the time and gave me that impression (rare on Silverados)
As long as shipping them to you is not too much, they are all in the original box and ready to go anywhere ;)
I'm looking at the maxtrac 3" level as of now.  I just want to level the truck for the summer and then drop it back down when I get bored.  If I need to I'll order the reklez upper arms if the balljoint angle is to much
Anyone see an issue with this?
Just want to pass this on....Installed the MotoFab 1.5 under strut spacer block. Piece of cake. Loosened sway bar link, unbolted bottom of strut, removed upper ball joint nut and thats was it. No unbolting of the tie rod or loosening of the 3 upper strut bolts. Start to finish 45 minutes. Perfect .5 inch rake from back to front, exactly what I was looking for.
27 minutes ago, Tyy1907 said:
Well taken photo
2.5" front?
Yessir, stock block
thanks man
Edited by texasaggies16
Anyone fit 295/70/17 on a 2" level? Not many pics online and trying to see how they look compared to 285/70/17
With stock wheels and minor trimming. With aftermarket wheels be prepared to start cutting.
Detailed it after getting it back from the body shop! Had transportation damage on the roof upon arrival from purchase date. All covered under GMC.
Edited by MHardiman90
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
