On ‎5‎/‎18‎/‎2018 at 10:31 PM, jgraves13 said:
UCA and a diff drop don't help lower balljoints. Do it right the first time, even if it takes a little bit more time to save
It's not the money, I just preferred to level it out without jacking it up and without wearing things out. It seems lifts include provisions to address the LCAs and stuff too.
Meh.
At this point, I'm leaning more towards trading it in on a ZR2 rather than trying to make it something its not.
2" RC level, 295/70/17 nitto Terra grappler G2. Little bit of rubbing on the plastic and felt liner in the back, but don't have trim any metal!
What is everyone running over factory specs for front end alignment?  The level kit manufacturer says to run factory specs but that has lead to cords showing on the outside edge of tires.  Anyone have or remember what there setting were as far as toe in and camber?  Need new tires and the alignment guys said the best they can do is trial and error, adjust and check in a few thousand miles.
I don't have the setting, but would echo his advice...I got mine leveled, aligned and then new tires...(plug for Discount Tire) I take them in religiously at 5k miles and get them rotated and checked for wear...absolutely no uneven wear at all, and my tires really didn't even show any (normal) wear until about 25k miles, when they just started to look like i drove on them...
**2" RC front level, didn't touch the back...factory wheels, 285/65R18 KO2 BFG
  I had the tire shop set toe in at -0.12 left and-0.13 right.  Factory setting was .05 and .05.  Will see what happens.  In desperate need for new tires now.  Asked if tire guy could turn my tires on the rim so wore side is opposite of where it is and would not do.  Would like to monitor where on these old tires a bit.  Maybe flop backs to fronts.
Edited by Buckem
Just an FYI. Simpletire.com has dirt cheap prices and an additional 15% off Toyo right now. Got 4 33’s for $979 to my door!
2015 Silverado LT 4x4. Motofab 3" front lift and 1" in back.
On Nitto Terra Grappler G2's.
285 x 70 x 17
American Racing 910 Wheels.
Hey guys,
New to the forum and I’ve got to say thanks because I was able to get a good idea of what I wanted to do to my truck by scrolling through all the awesome trucks on here.
Here is my new to me 2014 GMC Sierra SLT.
I use my bed everyday so I opted to do the 2” Motofab Level to maintain a bit of rake. Really happy with the way it turned out.
Before and After:
Edited by Leans
I have read conflicting information on this site and have also received conflicting information from different tire shops around town.  Can anyone chime in with experience?
I have a 2017 GMC 1500 SLT 2wd with a 2" front level (Motofab upper strut "donut")
Can I fit a 33" x 12.5" on the OEM 20" wheels, or should I go with the 275/60/R20?
I have also researched a 295/55/R20.  I am hoping for a 33" tire with maximum width and avoiding any rubbing issues.
I imagine you'll rub UCA at full lock with the 12.5" on stock wheels. I barely rub at full lock with 275/60/20 on stock wheels with Bilstein 5100 at the top setting.
Thank you.
Evening!  New to the forum and back to the Sierra family.  Traded a ‘13 in on a car then decided we really needed a truck so ended up with a ‘15 SLE.  I noticed it had a leveling kit and doing some more looking, it has a thicker block in back and Rancho shocks.  I saw on a FB group that some came from factory with the bigger blocks in rear and  Rancho shocks but wasn’t sure if the front would have had the leveling kit?  Just trying to verify.
Thanks!
I installed my Motofab 2" front level myself last weekend.  It is the upper strut "doughnut" style spacer.  I had an alignment done by the local tire shop the next day. Initially, everything rode well and nothing was making noise.
Now, 6 days after install, I hear a knocking style noise when I turn the steering wheel at slow speeds.  I can only make the noise happen while traveling very slow in parking lots and turning the wheel almost to full lock.  It is usually 2-3 knocks.  It happens when turning the wheel and then happens again while straightening out - almost as if something is shifting, and then shifting back.  I re-checked tightness of all components that were loosened for the install (tie-rod, sway bar, upper and lower strut mount bolts).
Because this only happens at extreme turns during slow speeds, I am wondering if it is the tie-rod connections.  Possibly they are over-torqued?
Does anyone have a recommended torque value for the tie-rods and any other suggestions on what may be the culprit?
What year is your truck?
    morrislh
    morrislh
  • Who's Online   5 Members, 0 Anonymous, 891 Guests (See full list)
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
