Ok, so what is the consensus? What brands are the best bang for the buck these days? I'm looking to replace my Jegs catch can because it's too small...only get about 300 miles before its full.
I'm looking to stay around $125.
Sent from my SAMSUNG-SM-G730A using Tapatalk
I think you need to increase your budget. Otherwise, you may be throwing good money away after bad. I started shopping for for quality first and then price. I ended up with Elite Engineering and RX Performance on my short list.
I picked Elite because of price and the batter bay bracket for my 2015 GMC. Elite's customer service is outstanding and I only learned that after the sale.
Good luck.
There are a lot of good Catch Cans on the market, there's also a lot of junk. Some are just empty beer cans without any internal baffling for the oil vapor to condense on. Be sure to choose a Catch Can that's been around for a while, with good engineering and design. Also, one that's easy to inspect and/or empty.
I understand this, been reading this topic for a while and have a Jeg's installed (as an entry level to see what I caught).
Good luck.
There are a lot of quality units in this price range, including the Elite. I've considered the Elite and the Conceptual Poly cans, then Moroso and http://www.mishimoto.com/ .
Whast up guys, I installed my can a few weeks ago. Here are some pics. about 800miles in.
I think I bought the same CC as pictured where did u mount it can't really tell how and where u mounted it also which hose went where? Thanks
I started a thread on the Saikou Michi cans, half the price of an RX, performs just as good, brackets are designed for our engine bays, holds a good 10 ounces. Ask for a single can system and you'll be in your price range, add another 50-60 bucks and you can get a dual system.
The only thing I didn't like about the Saikou Michi is that it is a completely sealed can...I'm one for taking things apart and cleaning. My biggest concern with a sealed can is winter...I swabbed out jello from my jegs unit, and was lucky enough that in unscrewed. That stuff would not have drained from a petcock.
I've pretty much set upon the CP can, and maybe even the aluminum body...still like to see what's going on in there. I guess my reasoning is that I have the Jegs, I see how it works and how well it works, and the CP is a very similar design (just larger).
That is really good to know. Thanks. Glad I went with the Elite. You and I have the same climate.
Hope to get mine installed today or tomorrow now that it has warmed up a bit.
I also asked Steve if I needed the larger can. He said the regular can will have no problem going from oil change to oil change without needing emptied - even in cold climates where I am at.
He was very helpful.
I don't see how this is possible unless the can doesn't work as well as the RX or it has a 40+ ounce reservoir capacity. My RX can is draining approximately 6 ounces of fluid every 750 miles here in Virginia. At that rate it would need to hold at LEAST 40 oz for me to make it 5,000 miles. There's no way I'd ever go that long in the winter.
Edited by Silverado-Hareek
Every engine is different...the expulsion rate of vapor through the PCV is variable. I would get maybe two ounces in 750k, and even if your RX was twice as efficient as my Jegs, that would only be four ounces.
2 oz in Reading, PA every 750 miles? Is that a diesel engine or gas?
Agreed every engine is different. But same engine, relatively same climate, and a 4 oz difference in stuff being caught per 750 miles....that's a can performance issue in my book. At any rate, I still don't see how you can go 5,000 miles in winter conditions based on the photos people are posting in this thread. In the summer time yes probably.
Ok, no reasoning with fanboys. Forget I responded.
I WILL forget you responded since you obviously are incapable of having civil discussion with another individual.
For anyone else willing to discuss the issue, I'm here and ready to talk. For the record, I'm not a "fanboy" of RX. While I did buy their can, I agree there are other great cans available. If you take the time to read my original post from earlier today, I'm approaching this discussion based strictly on numbers and facts such us climate, engine type, # of miles, etc. I question the statement about being able to drain a catch can every oil change when you live in winter climates. Again based on what others and myself are pulling out of our cans, that doesn't seem physically possible without sucking gunk into your engine.
And again, there are too many variables to compare one engine to another. Period.
This like trying to compare used oil analyses...it's pointless. It only shows how well it's working for that particular engine.
Edited by sdeeter19555
Maybe there is something wrong with your truck?
    JWeather
    JWeather
  • Who's Online   3 Members, 0 Anonymous, 332 Guests (See full list)
