Wow all i got to say is Elite Engineering is a great company and great customer support. You can't go wrong with this can. I got my about a month ago and now they have a specific bracket to mount it in the extra battery tray or on the brake booster like the RX can. They are sending me that battery tray bracket and extra hose for free since I have just the "hockey stick" looking bracket attached on my drivers head on the engine now and it rubs on the vacuum hose a little on my truck now. Still not a bad install but a specific bracket would be wonderful. And to answer a post above you mount the connection under the throttle body to the top inlet of can and the side outlet of can to the connection half way down the intake manifold. This is the correct way.
I have their gen 1 can on my 03' top quality for sure. Could you post a picture of the battery tray mount when you get it in?
Found one for the silverado..... I run one on my SC Camaro as well . Been a believer since day one.
Brian
Edited by epstein
Steve at Elite Engineering just sent me a detailed installation guide yesterday. I found it to be very helpful. My Elite can is on its way.
Catch_Can_Install_Chevy_GMC_2014_5.3L_6.2L_Truck
https://drive.google.com/file/d/0B6qYnGsTf7BcQjNBd2JjZEVHY0VFUUhSeFhnZkRfTlA0MWtB/view?usp=sharing
These instructions show the can being mounted to the master cylinder housing. I asked Steve if i could mount mine in the empty battery tray behind the driver's side headlight. He said no problem and is including the proper bracket to mount it there with my order.
I also asked Steve if I needed the larger can. He said the regular can will have no problem going from oil change to oil change without needing emptied - even in cold climates where I am at.
He was very helpful.
They must have just recently got those docs together. Steve answered a number of questions for me about a month ago when I went to order mine but they didn't have instructions for the ecotecs then. He was very quick to respond, no complaints.
But if you have the same regular size can I have you might be surprised how fast it fills up. I had mine full after a week and only 350 miles. It's mostly water but I'm now dumping an oz or 2 every few days. I live in MI. Honestly I really like the can but would prefer one that held a much larger quantity.
Suggestion . Why dont you thread a petcock on the bottom and just open it once a week? I have one on my camaro and drain it every oil change.
Here's a picture of the Battery Tray mount. This set-up is shown with the Black AN swivel hose fittings.
Was bored, so I drain the Rx cc at only 301 miles after install and it was just under 2oz.
WOW that's some black nasty oil!!! I get 2-3 oz's but mainly water.
RT
Yup, the weather out here is always like summer, with a few showers her and there.......lucky to live in Hawaii.
Yeah....Love me some Hula Girls for sure!!!!
RT
Put mine on this weekend. I day of driving (36 miles). This is what i got just about an ounce.
Jesus the relief on your face lol
I was shocked when i saw all that nasty stuff in there. I thought I might just have enough to cover the bottom of th can.
Ok, so what is the consensus? What brands are the best bang for the buck these days? I'm looking to replace my Jegs catch can because it's too small...only get about 300 miles before its full.
I'm looking to stay around $125.
Sent from my SAMSUNG-SM-G730A using Tapatalk
There are a lot of good Catch Cans on the market, there's also a lot of junk. Some are just empty beer cans without any internal baffling for the oil vapor to condense on. Be sure to choose a Catch Can that's been around for a while, with good engineering and design. Also, one that's easy to inspect and/or empty.
    • Shock and spring rates are specific to the NHT max tow package.  Changing them will alter the performance of the suspension.   Not even the factory GM Trail Boss 2 in lift is compatible with NHT trucks as well.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
