The only thing I didn't like about the Saikou Michi is that it is a completely sealed can...I'm one for taking things apart and cleaning. My biggest concern with a sealed can is winter...I swabbed out jello from my jegs unit, and was lucky enough that in unscrewed. That stuff would not have drained from a petcock.
I've pretty much set upon the CP can, and maybe even the aluminum body...still like to see what's going on in there. I guess my reasoning is that I have the Jegs, I see how it works and how well it works, and the CP is a very similar design (just larger).
No worries, I always drain after the trucks been driving at full operating temp for a while to avoid anything like that.
I could see that...
Did you buy a stock can with the 1/2" barbs or did you have the custom make one with 3/8"?
Sent from my SAMSUNG-SM-G730A using Tapatalk
I like that!
I sent saikou-michi an email about availability. I have until June to install a replacement for the Jegs.
My biggest issue with ANY catch can option right now is space. The hydroboost prevents using the master cylinder, and I have a spare battery in the second tray. I'm limited to either a custom bracket floating it between the engine and battery, or drilling and bolting to the alternator bracket.
I like that!
Yea, I think the final model is complete. He just drafted up an adjustable leg for the bottom support on the can last week so I think after I toss that on, update the product overview - it's good to go.
Maybe there is something wrong with your truck?
I don't think so because of the ratio of oil versus water. I'm getting approximately 2 oz of oil and and 4 oz of water. It's hard to tell the exact difference because of the moisture content but that's close enough. So based on the oil quantity, I don't think there's anything wrong. Being that it's mostly moisture in the drained fluid, that's pretty typical for an engine in the winter time to have a lot of moisture like that. It should settle back down to just oil in the summer. If it doesn't settle back down or if it were more than 2 oz of oil, I would definitely be concerned though.
I plan on getting an inline check valve. What's the value of having baffles in the can?
It's a necessity. It gives the oil vapor something to condense and adhere too. Without the baffles, it's just an empty can that does not do a sufficient job of filtering out all the oil.
I too have gotten a lot of water / oil from my RX can during this past winter. As stated in a previous post, I got nearly 10.5 oz of 50% water vs oil after 1000 miles. I completely agree with your findings. In fact yesterday, I was able to wash the truck and I drained the cc again after about 250 miles. I got about 2 ounces of 50 / 50 water to oil mix.
During the summer, I collected nothing but oil. It is weather dependent in my opinion. I think your engine is fine, it's just the extreme cold we've experienced that has added to the gunk we've collected.
Yeah it's definitely the colder weather. I also drain after driving the truck for a while to make sure all of the oil and water is warm so it flows and isn't frozen or coagulated in any way.
And just to clarify again for anyone that may have misunderstood me, my original point a few posts back wasn't to knock any particular brand of catch can. I was merely trying to state that I don't see any way you could ever go 5,000 miles between drains in a cold weather climate.
Edited by Silverado-Hareek
Well, pulled the trigger on the Conceptual Polymer can, with the aluminum body and HE filter...I really wanted the glass body, but the aluminum version just removes the potential for me to drop and break the glass body. The aluminum version also provides about double the capacity of the glass version, something like 5 ounces or so.
Because I have the second battery and hydroboost, I need to build a bracket from the fender to the engine compartment, with a knee brace from the second battery tray. Should take an hour or so to build, since it will need bending, welding, and drilling. But I need to wait for the CP to arrive so I can make my measurements...probably install next week.
One thing I was thinking the other night is our use of high grade synthetics...in my previous trucks (colder running diesel), you could literally run synthetic through the combustion process (some guys ran their drain oil through the fuel system) and catch it dripping out the tailpipe because it has such a high temperature tolerance. I'm sure synthetics in the gasser get smoked in the cat, but at what cost?
I also took note last night that someone indicated their tailpipe wasn't nearly as black as it was prior to the installation of the catch can, I looked today and mine isn't as sooty as it was previously either...maybe? If it was from un-burnt fuel, should be worse since we are running the rich cycle longer due to the cold weather?
I think I bought the same CC as pictured where did u mount it can't really tell how and where u mounted it also which hose went where? Thanks
ill take better pics tomorrow. But the top line goes to the bottom fitting by the throttle body and the center one goes to the rear fitting on the manifold.
Edited by gary03l
The Catch Can hoses should be routed in this manner.
Hmmm is that a 2014 5.3? I thought hoses connected half way down engine drivers side and under throttle body?
You are correct. That would be a 6.2 motor.
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
