The stuff in the can will freeze if there's a lot of moisture/water in the drained fluid. I left it outside in an oil drain pan overnight one time and it was solid ice the next morning. But with that being said freezing should only be an issue if your can is too full which would be a problem anyway because you don't want it to get too full and the mixture get sucked into your intake.
Installed mine at 3,174 miles. After just two days and 57 miles driven. Half country roads and city miles with a couple remote starts since its been around 0°F here. I had about a shot glass worth. I was very surprised at the amount collected. At this rate it'll need to be dumped every fill-up. Its baffling that GM would consider this amount of oily residue to be passed back into the intake acceptable. I mean just look at it sticking around the upper rim and to the bottom of the can! I've been down that road with my wife's former Acadia. Peace of mind that I'll hopefully avoid those issues with this truck.
Wow that's alot I installed mine at 2400 so far have about 100 miles and I thought 500 was too soon by seeing urs at 57 miles smh I can only imagine mine.
Drive about 100 miles yesterday and this morning I checked the can. I have just enough to cover the bottom. Amazing how gm figures this much oil is ok to be run back through the engine.
Granted, most of this is just condensation. Still good to get it out of the motor tho.
I agree. There was more sticky oily residue clinging inside the can which would have ended up on the valves than I would have imagined after only 57 miles.
Got my can installed today. Mounted it to the front support bracket off the fender. Did have a little hiss. Pushed the bottom line on to the engine more. Got rid of most of the hiss. Still had a little. I'm thinking it's the air moving through the can lines. Read some other threads and some have modified the stock piece but I'm going to get a few clamps to tighten everything up a little more. Have a drive from Illinois to Florida here in a couple weeks. Want to make sure everything is good.
Just drained my RX can after a little over 1000 miles. I was shocked when over 10-1/2 ounces drained! After letting it sit for a bit, the mix was about 50-50 water to oil, and it was tan in color. It has been the coldest month since they started keeping records over 125 years ago so I'm sure that may have something to do with it.
Does anyone know how much the RX can can hold?
In any case, I have no doubt about the effectiveness of the RX catch can. I'm really glad I installed it.
cooler the can the more vapor will condense on the inside and that is why I'd like to hook mine up to the cool side line of my A/C. Not a big deal for people up north, but here in Florida I think it will help catch more stuff almost year round.
It says 1 QT on their website which is 32 ounces but I think that's total can capacity or interior volume so you have to account for the filtration portion at the top. I'm not sure what the actual capacity of the safe reservoir area is but I've been draining mine every 750 miles or so in the winter to ensure it doesn't get overfilled. I really wish RX made their cans like some of the competition where you can see how full it is or at least unscrew the bottom to get an idea of how much storage capacity you actually have to gamble with.
So is the RX can pretty much the one to get, I think you have all officially scared me into getting one lol?
I wouldn't think twice about it. It simply works!
Based on what I've read after countless hours of research on the internet, it seems to be the most effective on the market. There are other ones that are just as great too. But there's a link somewhere where someone tested multiple cans and found the RX to catch the most "stuff" out of all of the cans tested. That sealed the deal for me. That and pretty much every Corvette or Camaro forum was also recommending RX.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
