Never been a Dodge fan but I thought the ram 1500 was supposed to have a more plush ride than the GM twins. Not the case?
I came from a ‘14 1500 Ecodiesel before my ‘17 Denali, and I do miss the smooth ride of the Ram. I think the interior was better in the Ram too, but that’s all I miss. Things would have to take a serious turn for me to leave GMC now [emoji106]
Edit: I would probably be happy with a Raptor too if I’m honest ?
On 4/19/2018 at 4:06 PM, Slabsides45 said:
I did the same with my 2015 Crew, same wheels with some Toyo Open Country 34.6" tires.  Really like the look of those wheels on my Brownstone 4x4.
Do they look different on 2wd brownstones?
Tyler
Tyler
Yes, they sit closer to the ground and smell like Geritol and Ben Gay.
Here's my new to me '14.  Will have a 2.5"/3" level and wheels and tires (33x12.5) some time this year.
2018 Silverado LT Double Cab got 20" wheels.
On 4/22/2018 at 11:39 PM, jeffwilson1210 said:
2.5 rc level 3” block, 275/70/18 falken wildapeak at3w, edge cts2 so far, just ordered 20x10 fuel Mavericks w 275/55/20 Toyo at’s will update soon
Before you swap tires, can you take some measurements for me?   I don't typically like a 275/70 because they are so narrow, but those look good.
What is the tread width (edge to edge)?
What is the section width (bulge to bulge)?
Total mounted height?
Also, a pic from the back and front to see the width of the tire.
Thank you!
Thank you!
Damn bro I just put my truck in the shop this morning for the new wheel setup. Sorry!!
But I was skeptical as well w it being so narrow, but when I got them mounted I was pretty happy
Did you get rid of the rims and tires already?    measurements mounted but not on the truck would be OK too.
I don't think you're gonna like the ride of those new 20s!!
I’m picking it up tomorrow after work I will give you the measurements then. Don’t say that haha we’ll see though.
20180414_140247.thumb.jpg.0296751e020cf436428d10d16aeb59ae.jpgnew around here thought  I would show of my 2017 rclb she runs 35 12.5 17 with just a 2 inch leveling the front
Nice ride!  What tires are those?  AT or MT?
Anything will fit with enough trimming! How much did you have to do?
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
