9 hours ago, spenpet said:
I do about 20k per year on mine...I am willing to bet there are a lot of folks that put A LOT more per year than me...30K is just a break in...;)
***Wrong quote***
Edited by royrjs
8 hours ago, Frankielozano214 said:
I’ve had my truck since April and already put 12,000 miles on it, got it with 71,000.
What version or aftermarket display is that?
It’s not aftermarket it’s actually the Denali cluster a lot nicer then the regular ltz Chevy Cluster  have acouple for sell if interested. HMU can check with whiteautoandmedia.com compatibility
Edited by Frankielozano214
Hey all, new to the family here. Picked up a 2016 Sierra 1500 Denali Crew Cab Standard Box with 22k miles on it a couple weeks ago. Loving it so far! I got some rubber floor mats for the front and rear, getting windows tinted next week and I had a 2.25" leveling kit installed. Really liking the way it sits now that it's leveled out. Next will be some tires once I decide what size I want to go with, hoping to go as big as I can without any rubbing and will be keeping the stock rims. If anyone has any input on that it would be much appreciated!
I attached some pictures of the truck in the rice field putting out decoys and then a before and after the leveling kit. Can't wait to do some more mods!
  • Like 5
Very nice. I have a 2014 twin. Denali, 153" wheel base, Iridium Metallic. :)
'18 Z71 eibach pro lift set at 2.5", Freedom UCA's,Motofab 2" rear blocks, Avs bugflector 2 and low profile window vents, rough country hd2 running boards, kx offroad 2's wrapped with Falken Wildpeak AT3's.2c3509e7e00d0514a384a139ba00458e.jpg
Put my snow plow on the truck for the little bit we had (plus had to move it from its current location to the new spot in the driveway).
Poor red truck had to sleep outside at -12 F... big brother needed some maintenance.
Stolen parking spot.... it was tough to push inside on snow and below zero by myself! ?
    • I have 2 choices.
