2 minutes ago, JimCost2014 said:
I would think Pinto bashing is an acceptable topic in any GM forum😂🤣🤣😂😬
Oh, heck, let's not speak of the Corvair ... My Nanny had one, I loved it! :D
I still love that car!
My Mom sent me the receipt from when she bought it - treasured memories ...
Edited by MikeBMW
The Corvair was GM's attempt at a mid-engine car to compete with Porches, and other in the lower Trans Am series.
The Turbo versions are worth a lot of money these days.
Chevrolet designed a car that deviated from traditional American norms of design, powered by an air-cooled, horizontally opposed six-cylinder engine with many major components in aluminum. The engine was mounted in the rear of the car, driving the rear wheels through a compact transaxle. Suspension was independent at all four wheels. Bodywork used monocoque rather that body-on-frame construction. The tires were a wider, low-profile design mounted on wider wheels. The styling was unconventional for Detroit, with no tail-fins or chrome grille. Its engineering earned numerous patents. Time magazine put Ed Cole and the Corvair on the cover, and Motor Trend named the Corvair as the 1960 "Car of the Year".
I have a pic of me, as a kid, by the Corvair from long ago.
I'll have to search it up, and the receipt.
I'll post it in the off-topic forum for a Corvair thread when I get it all sorted. :)
10 hours ago, poconojoe said:
That's crazy! I don't blame your wife. That had to be scary!
What's the deal? A defective suspension from the factory?
Has anyone else had this problem?
I think if this was common it would be well known.
I don't doubt you from your description, but it seems unique. I would have brought it back to the dealer for them to explain what was wrong.
Anyway, what mods did you do to correct it?
What is wrong is a half ton truck sprung to carry a full ton and price point shocks along with a crazy dose of castor. It is aggravated with the RCSB models as the wheelbase is shorter. I fit new springs and King shocks front and back, dialed back the castor to 2* and problem solved. While I was at it, dropped it 1/4.
2 hours ago, JimCost2014 said:
Come on now, how many Pinto's actually exploded from having an exposed gas tank at the rear of the car🤣😂🤣😂
Look how much money Ford saved by literally "chopping" a foot off that car.
I actually had the Corvair in mind :P
A little off topic, but close, I can get the front tires off the ground with the factory Rancho's going over speed bumps at slow speeds. Kind of like a bunny hop.
The Z71 has a very stiff suspension, does not like the washboard type freeways either.
Just put on a few 35x12.5x18s with, I think, about an extra 150 ponds.
Settles it down a bit. :D
Yes, us older folks got that reference. Maybe the younger crowd didn't.
Found this pic of my truck recently I forgot I took after a quick wash. Thinking I may have posted before, but still looks the same.
Edited by Ge0rge
14 minutes ago, Ge0rge said:
Looks good in white!!
Thank you!
[IMG]https://uploads.tapatalk-cdn.com/20210721/57aa0b702eb7637f659b838ac050d025.jpeg[/IMG]
Thank you!
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,351 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
