Dodge = bad perception = bad image.
That's why "Ram" truck owners hate it when you call their truck a Dodge!
If you are going to go that route.
Just say Guts, Glory, Buy Back! :fart:
Got my light bar in finally :)
what kind did you get and do you have any install pics
hey its just a 30 inch cree led light bar. i removed the grill, drilled holes in those 2 bars in front on the rad and bolted it to it. piece of cake. about an hour and a half of work.
ok well let me know how it works can't make up my mind on witch one I want
Just had a 2.5" level and Toyo Open Country M/T 33's installed! Turned out great!
Edited by HookEm87
  • Like 5
works awesome!! i couldnt go without it now. makes a huge difference at night
Not sure if you're the first on here but the first I've noticed with a light bar behind the Z71 grill. I'd love a night shot to see how the light makes it through the grill.
Which level did you go with? I'm looking at Rough Country kits but would like other's input first!
Thanks,
I have the rc 2.5 level at home waiting to be installed. Nor getting tires right now so just gonna lift the front.
Sent from my SAMSUNG-SM-N910A using Tapatalk
I keep staring at the 2" RC leveling kit. Looks easy to install...only hang up is leased vehicle, but I will probably get it anyway.
It seems the RC leveling doesn't void warranty - anyone with input (redirect if necessary - I don't want to hijack this thread!).
Great pics, too, all. I look at this thread almost daily!
Not sure if you're the first on here but the first I've noticed with a light bar behind the Z71 grill. I'd love a night shot to see how the light makes it through the grill.[/quote
Sure man I'll get some tonight or at least try to lol it shines really good through the grill
Looking forward to it. I want to do the light bar behind my sierra. You said it's just a 30 inch cree led bar? Do you think the Eyourlife bar would work?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
