Haven't posted a pic in a while. Got her all cleaned up today.
What size tires are those?
Lol yes well am from houston so its pretty nice yea mines on a 4/6 drop right now and going to go another inch lower on the back
A friend of mine in KC just did a 5/7... looks good!
Just picked 14 slt with the 6.2. Already started modding
How does one resize an iPhone picture? It says it's too big
Not sure about iPhone without asking my daughter. My phone, if I open the picture, hit edit, crop it a little, and then save it, attach the cropped pic
I installed 5k HIDs in the fog lights. It's a 25 watt HID kit so it won't melt the small fog light housing. Headlights should be coming soon. Sorry My camera isn't the best showing the actual color of the HIDs but here you go 3bbcaf0671de7c56de6a04bff2d78076.jpg898a9a997eb4ca5be6df0decb2bd3dcb.jpgdf3550a9c5cfec71c579da1143545b36.jpgd3a35c1f93990ca7a0172247b515c34b.jpg
Please post a close up of the 5K foglight replacement when they are turned off. Interested to see the fitment in the OEM foglamp housing. Also, please specify the manufacturer and model of the 5k HID your using.
New to the forum and new 14' Sierra All Terrain. So far only 20% tint, LED conversion for the fogs/reverse/ect and HID's on the way.
  • Like 12
Nice!!
I like the grille. Is that a denali factory grille or aftermarket overlay?
They are both denali trucks. Both have 6.2 excpet one is lowered and the other has a small lift (mine). More pics...
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
