Rear Gearing and a Lift
KMGMC
Hey Guys,
I've been researching lift kits for the 2014 for a while now and I'm set on a McGaughys lift.
Problem is I have 3.08's in my truck and as far as I can find there's no after market ring and Pinions out yet.
Does anyone have any idea if the 2014 rear ends are the same as a 2013?
Really want to lift it but with 3.08's it just doesn't make sense to. I'm looking for 4.11's.
Any info is appreciated
Thanks
Sent from my iPhone using Tapatalk - now Free
Thanks, I guess I'll just have to wait it out
I'm looking at getting 35's, from pictures I've seen that seems to be what people are running.
Still not sure if I would go 3.73 or 4.11, really hoping Yukon will make gears for this rig.
You think 4.56 or 4.88, that sounds awful low to me. Especially with a 6 speed she'll be revving like crazy on the highway?
Although if I ever decide to go 37's I wouldn't have to change them again.
Do you have experience with gearing? And please don't take offence to that I'd just like more info on why, maybe you know things I don't.
Really asking now because BDS just released there 6 inch kit for the truck.
Has anyone opened that diff up? It looks an awful lot like the 9.5" 14 bolt they have built since 1979 just with 2 less bolts in the cover.
Sent from my SGH-I747M using Tapatalk
With a 4.56 rear and 35's you will be right around the 2000rpm mark at 65mph. You'll probably lose about 5-6 mpg's with the lift, tires, and rear end while cruising. With 4.10's you'll be around the 1800 mark. Have fun with this calculator so you can figure out what you want.
http://chevellestuff.net/tools/rpm_calculator.htm
The 6L80E ratios are as follows:
1st - 4.027
2nd - 2.364
3rd - 1.532
4th - 1.152
5th - 0.852
6th - 0.667
Rev - 3.064
Will
With big tires that should be nearly perfect. I know you have more power, but I like my truck to run ~2k rpm on the highway so I rarely have to downshift. With 4.10's your truck will have to work harder than with 4.56's, your fuel mileage should be about the same except it'll be more driveable, especially around town.
That was always my plan to put the least amount of stress on the truck as possible.
Ya I'm not worried about gas mileage at all. I think it's kind of funny when people lift a truck then worry about gas mileage doesn't really make a whole lot of sense to me.
So sounds like I should be in the market for a 4.56.
Anyone got an opinions on the mcgaughy lift? I checked it out and it seems pretty well built. I just have never heard a bad thing about bds and have used them in the past with no problems. I also like how bds doesn't use a spacer on the front where McGaughys does.
My truck is geared with 4.88s and I have a little knowledge in the gearing dept. there is an active thread right now where a Denali owner is disappointed with 4.10s and that's with a 6spd and 6.2, of course. The final drive ratio should be about he same with the 6spd vs the 4spd, so I wouldn't worry. I wouldn't hesitate to run 4.88s with 35s, which is exactly what I did. I now have 37s but I preferred the feel with 35s. Gearing charts are a good measure but they really only take into consideration the tire diameter. You should also consider the added weight of the tires and larger wheels as well as the added rolling resistance. 4.56 is a safe and balanced bet but since you're not too worried about fuel mileage and may even consider 37s later then I would got with 88s.
  • 6 months later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
