Ford F-150 makes you wear a seatbelt?
My dad has a 2012 Ford F-150. In the past he told me if the seat belt is not buckled the radio will not play. I found it hard to believe. However yesterday when he picked me up the message center on the dash said something like audio will be unmuted when seat belt is buckled. Sure enough when I buckled my seat belt up the radio came back on and the message went away. So I guess Ford makes you wear the seat belt or else? Has anyone seen this before?
That is clearly blatant discrimination and bias against younger drivers in general and teenagers in particular. Bring on the lawyers immediately!
I don't think it hurts you any to wear your seatbelt... I can't speak for a ford but even my 8 year old truck has good enough brakes to throw me out of my seat.
It's an option that he doesn't know how to disable. It's called MyKey and it's to help helicopter parents keep tabs on going drivers. When enabled the top speed can be limited to 80 with warning chimes at speeds of your choice, it will mute the radio, prevent traction control from being turned off and maybe some other stuff.
If it wasn't that it's the annoying repetitive chime they use.... I always wear my seatbelt but when Partridge hunting, crawling on the logging roads throughout the property? I Don't..... and If Ford was so damn smart why do they make the rear seat belt buckle that clicks into the driver's buckle? ;)
I disabled my driver side seat belt dinger so that when I'm riding around the farm I can get in and out and not be constantly annoyed but mine has never shut the radio off.
I did the exact same, easy to disable
No it doesn't hurt.
But there are times that require the non use of such.
Trucks are the last bastion of avoidance of the socially/politically correct types.
Leave the trucks alone.
here's what Ford says the features are for MyKey:
The easily programmable system features several options:
  • Persistent Ford Belt-Minder® with audio mute sounds
    chimes and mutes the radio to remind teens to buckle up. A message on
    the instrument panel is also displayed: “Buckle Up to Unmute Radio”
  • Volume control can limit the audio system to 44 percent of maximum output if the radio is too loud
  • A speed alert chime at 45, 55 and 65 mph will remind teens to slow down. Parents can also limit top speed to 80 mph
  • “Do Not Disturb” helps parents block incoming phone calls and hold text messages on a phone paired with Ford SYNC® when teens are behind the wheel
  • In addition to the typical warnings displayed when the fuel level
    reaches 25 and 50 miles to empty, MyKey provides an extra warning at 75
    miles to remind your teen to fill up
so yeah, Ford MyKey is pretty much a Big Brother System for Teenage Drivers thought up by Paranoid Parents. (and from what MikeNH has mentioned before, some Rental Companies that have Fords Equipped with MyKey use the Speed Limiting Feature so the cars won't get beaten to death.)
I don't know for sure it was the rental company who turned it on in the first place, it's pointless to do since the other key on the key ring was the admin key. I just disabled it. It could've been a previous renter looking to mess with people. I may or may not occasionally switch voice prompts for Bluetooth on rentals to French. Same deal. :lol:
Darn, I should have done that to the '13 Cruze we rented back in June, because it had the MyLink Radio!
I still think the old fashioned " I catch you or hear about you driving like an idiot/not wearing a belt/racing, etc You lose the keys" system from the old man works better than this.... Hell I know I sure wouldn't have wanted to be seen without a belt and have it get back to him......
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
