I custom made a bracket for mine cause it wouldnt work with my new McGaughy's lift, I have a pic on my phone that I'll post up in a minute. And if you want to tighten up your steering, get a Cognito pitman/ idler arm support kit, really helped me on my 35's, bet it would do even more on your stock size tires as well. Only downfall is is that the kit is a little pricey
http://cognitomotorsports.com/chevy-gmc/steering-kits/cognito-pitmanidlersupportkit-pisk2006-truck.html
Honestly that's not really too much IMO. Since I'm over 100k I'm starting to think it's about time to redo ball joints, steering ends and bushings.
This is the plate I made to mount where the bolts hold the passenger side of the front diff. to the frame. A longer bolt and some washers may be needed though to provide clearance, or not because your truck is stock height and I mounted mine to the drop bracket of the lift so it torqued it at a steep angle. If you want the dimensions for the plate, I still have them laying around
That's the bracket they give to you with the kit. Where I figured to mount it was extend the stabilizer all the way out, measure it, push it back in half way, and then attach the stabilizer to the custom bracket and then the one provided and mount it from there. You can also see the support bracket for the Cognito kit I was talking about. Basically sandwiches the drag link and uses heim joints and sleeved nuts to do the job
And there is the final product!
Any questions or more pics and I will get them for you!
Edited by rdnckhntr94
Very cool, thanks. Looks like getting it mounted shouldn't be too hard. If all I have to do is make a little plate it won't take too long.
Edited by kstruckcountry
That is how mine looks but you made it fash as well while I made it DRL
Still my favorite body style. Can't wait to own another one in the future. Great looking truck!
Thanks guys!
I think either way it looks good Chris. Looks a lot nicer all lit up vs stock.
I have my steering stabilizer sitting in the shop, I just have to make a bracket to mount it. Sometime.
Also ordering new torsion bar crossmember bushings/mounts, mine are trashed. If you have a torsion bar front end and it's clunking under your feet, check them. :)
Those are bout $40-$50 a piece and be prepared to grind or drill out the old rivets. Not too bad though. Then I installed this lift and it doesn't use them, oh well lol
Sent from the side of the road...
Yeah very straight forward. Just grind them flat and drill em out. If you have a good bit and keep it oiled it should only take 15 min.
Get a longer bolt on the differential mount side and stack washers until you get the height you need. But that could cause other clearance issues as well
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
