quise2024 Posted February 7, 2017 Posted February 7, 2017 looking good. Any photo of the front with your Z71 grill . How much light got block by cross bars ? A day later lol Here you go via Tapatalk on Galaxy Note 4 2
slj2008 Posted February 7, 2017 Posted February 7, 2017 A day later lol Here you go via Tapatalk on Galaxy Note 4 looks good. Thank you for the photo. how much light would be loss with a double row ?????
quise2024 Posted February 8, 2017 Posted February 8, 2017 (edited) looks good. Thank you for the photo. how much light would be loss with a double row ????? Im not sure if thats measureable but regardless the light still shines thru. Only reason i didnt go double is because it will for sure cover up some of the bulbs/lights (w/e u call it) but the light still shines. Not sure if im making sense there .. ill grab a pic really quick of someone elses Update: Ok not my photo, this from the SS forum who helped me out deciding what to get. He had the RC curved dbl, switched to the single. Here is his dbl row. You can that the top row is blocked. It will still shine but light will just go up n down rather than forward via Tapatalk on Galaxy Note 4 Edited February 8, 2017 by quise2024 2
CbrownGT Posted February 8, 2017 Posted February 8, 2017 I went ahead and ordered up a brake controller panel and diced it up for my switches. Here's a few pics: Where did you get the brake controller plate from and how much? Also, how did you get the power for your switches to light up, like the words on the bottom part? 2
Denali 101 Posted February 8, 2017 Posted February 8, 2017 Where did you get the brake controller plate from and how much? Also, how did you get the power for your switches to light up, like the words on the bottom part? I chose to wire the bottom led off the parking lamp circuit. The top part comes on when the switch is rocked active. Plate was off amazon. Find them all over the place right now on ebay, gm parts direct, rock auto had 2 in stock last week for 5 bucks more and : https://www.amazon.com/ACDelco-23476237-Original-Equipment-Assembly/dp/B010GLVW90/ref=sr_1_1?s=automotive&ie=UTF8&qid=1486517945&sr=1-1&keywords=23476237 Ebay listings: http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X23476237.TRS0&_nkw=23476237&_sacat=0 1
CbrownGT Posted February 8, 2017 Posted February 8, 2017 I chose to wire the bottom led off the parking lamp circuit. The top part comes on when the switch is rocked active. Plate was off amazon. Find them all over the place right now on ebay, gm parts direct, rock auto had 2 in stock last week for 5 bucks more and : https://www.amazon.com/ACDelco-23476237-Original-Equipment-Assembly/dp/B010GLVW90/ref=sr_1_1?s=automotive&ie=UTF8&qid=1486517945&sr=1-1&keywords=23476237 Ebay listings: http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X23476237.TRS0&_nkw=23476237&_sacat=0 Thanks. I actually did some digging in the forum and found a previous part of this thread that listed a part number for just the plate, minus the factory brake controller switch. $14-16 depending where you buy. Here's a link to it with a price and picture https://www.tascaparts.com/oe-gm/22830877?origin=pla&gclid=Cj0KEQiA_eXEBRDP8fnIlJDXxsIBEiQAAGfyod40NB5-yy5_xqk7rDII1vX9DUu0DDS8Jp4EgpJYjisaAvlq8P8HAQ 3
Denali 101 Posted February 8, 2017 Posted February 8, 2017 Thanks. I actually did some digging in the forum and found a previous part of this thread that listed a part number for just the plate, minus the factory brake controller switch. $14-16 depending where you buy. Here's a link to it with a price and picture https://www.tascaparts.com/oe-gm/22830877?origin=pla&gclid=Cj0KEQiA_eXEBRDP8fnIlJDXxsIBEiQAAGfyod40NB5-yy5_xqk7rDII1vX9DUu0DDS8Jp4EgpJYjisaAvlq8P8HAQ There you go.
quise2024 Posted February 8, 2017 Posted February 8, 2017 (edited) . Edited February 8, 2017 by quise2024
bgweed Posted March 17, 2017 Posted March 17, 2017 Can you guys recommend some underhood locations to mount 2 relays side by side? Pics would be appreciated as well.
slj2008 Posted March 17, 2017 Posted March 17, 2017 looks good. Thank you for the photo. how much light would be loss with a double row ????? SO the single row is the best way ? is that rough county light / brackets ???? Thanks
GoBlue2014LT Posted March 17, 2017 Posted March 17, 2017 Mounted 32" light bar today. Still have to wire it up. Sent from my iPhone using Tapatalk 3
Lalibert Posted March 21, 2017 Posted March 21, 2017 Yeah i also have the trailer brake so theres no room on that panel for me. I like how this setup is from someone on amazon though .. this is same switch i bought just with a white light via Tapatalk on Galaxy Note 4 Do you have the amazon link? Sent from my iPad using Tapatalk
vettecowboy78 Posted March 24, 2017 Posted March 24, 2017 So I don't have the light bar installed yet BUT I installed the switch that I wanted to use today LOL. Here are the pics below. Keep in mind that my truck did not originally come with a center console, I installed it after buying the truck. I was able to get the USB ports to work. Prior to installing the center console, the truck had only one cigarette lighter so when I put the console in I left the second cigarette lighter alone with the intent of using it for a spot to install my aux switch. I had to remover the lighter and trim the switch a little but I think it turned out okay. The cover doesn't close completely but it's damn near close. Sent from my iPhone using Tapatalk 2
slj2008 Posted March 24, 2017 Posted March 24, 2017 So I don't have the light bar installed yet BUT I installed the switch that I wanted to use today LOL. Here are the pics below. Keep in mind that my truck did not originally come with a center console, I installed it after buying the truck. I was able to get the USB ports to work. Prior to installing the center console, the truck had only one cigarette lighter so when I put the console in I left the second cigarette lighter alone with the intent of using it for a spot to install my aux switch. I had to remover the lighter and trim the switch a little but I think it turned out okay. The cover doesn't close completely but it's damn near close. Sent from my iPhone using Tapatalk look good , need photos of light bar ??? Please
