looking good. Any photo of the front with your Z71 grill . How much light got block by cross bars ?
A day later lol
Here you go
via Tapatalk on Galaxy Note 4
A day later lol
Here you go
looks good. Thank you for the photo. how much light would be loss with a double row ?????
Im not sure if thats measureable but regardless the light still shines thru. Only reason i didnt go double is because it will for sure cover up some of the bulbs/lights (w/e u call it) but the light still shines. Not sure if im making sense there .. ill grab a pic really quick of someone elses
Update:
Ok not my photo, this from the SS forum who helped me out deciding what to get. He had the RC curved dbl, switched to the single.
Here is his dbl row. You can that the top row is blocked. It will still shine but light will just go up n down rather than forward
Edited by quise2024
I went ahead and ordered up a brake controller panel and diced it up for my switches. Here's a few pics:
Where did you get the brake controller plate from and how much? Also,
how did you get the power for your switches to light up, like the words on the bottom part?
I chose to wire the bottom led off the parking lamp circuit. The top part comes on when the switch is rocked active.
Plate was off amazon. Find them all over the place right now on ebay, gm parts direct, rock auto had 2 in stock last week for 5 bucks more and :
https://www.amazon.com/ACDelco-23476237-Original-Equipment-Assembly/dp/B010GLVW90/ref=sr_1_1?s=automotive&ie=UTF8&qid=1486517945&sr=1-1&keywords=23476237
Ebay listings:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X23476237.TRS0&_nkw=23476237&_sacat=0
Ebay listings:
Thanks. I actually did some digging in the forum and found a previous part of this thread that listed a part number for just the plate, minus the factory brake controller switch. $14-16 depending where you buy. Here's a link to it with a price and picture https://www.tascaparts.com/oe-gm/22830877?origin=pla&gclid=Cj0KEQiA_eXEBRDP8fnIlJDXxsIBEiQAAGfyod40NB5-yy5_xqk7rDII1vX9DUu0DDS8Jp4EgpJYjisaAvlq8P8HAQ
There you go.
Can you guys recommend some underhood locations to mount 2 relays side by side? Pics would be appreciated as well.
SO the single row is the best way ? is that rough county light / brackets ???? Thanks
Yeah i also have the trailer brake so theres no room on that panel for me. I like how this setup is from someone on amazon though .. this is same switch i bought just with a white light
Do you have the amazon link?
So I don't have the light bar installed yet BUT I installed the switch that I wanted to use today LOL. Here are the pics below.
Keep in mind that my truck did not originally come with a center console, I installed it after buying the truck. I was able to get the USB ports to work. Prior to installing the center console, the truck had only one cigarette lighter so when I put the console in I left the second cigarette lighter alone with the intent of using it for a spot to install my aux switch. I had to remover the lighter and trim the switch a little but I think it turned out okay. The cover doesn't close completely but it's damn near close.
look good , need photos of light bar ??? Please
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
