7 minutes ago, Bushleaguechew said:
Let us know how you end up mounting that upper bar
Saw someone else, on one of the other threads, do it, just going to us his, when/if I get around to it.  Been planning on installing my front hitch during my holiday break from work, back in '14, when I bought it.  Yeah, about that.  Life keeps changing my plans and getting in the way.  One of these days, I'll start a thread of my build/mods, will post it there.
Edited by Ravenkeeper
the double rows fit nicer on the gmc grills as they are a bit wider:
Wondering how easy it was for people to feed the light bar switch into the cabin. I've seen videos where they had to drill into this rubber grommet. Looks like a pain! How did you all get the switch in there nicely??
Sent from my Pixel 2 XL using Tapatalk
I did the kicker factory upgrade a while back and I just went through the same penetration as those wires which is in that rubber grommet you mentioned. It's really not that hard to wire through. I just took a razor and cut a small slit in the grommet and then fished a straightened clothes hanger with string taped to the end of it through the firewall and into the floor board. then taped my wires I was pulling through to the end of the string that's about it. Hope this helps
Yes it does! The video i saw had the guy cutting the little nib completely off and then sealing it with some clear sealant/caulk. But you're right -- if the wires are small enough (which i think they are) it should fit with a minimal cut.
I also found this! Might be useful:
On ‎1‎/‎10‎/‎2018 at 11:05 PM, sirooga said:
Rough Country 30" Single Row Lightbar Kitfc1b53e5e180409402c245cd965b0f5d.jpg
Nice setup,
Can I ask why you chose the very bottom row as opposed tot he one above it?
I would like to go in the slotted row above it to align with the signal lights straight across.
Installed a 42" curved bar behind the grille. Took some cutting and rigging and removing the entire grille and supports, including whats shown in the picture below.  All in all there were about 30 or more bolts to remove, misc. wiring, hood latch, and headlights.  I couldn't upload a better picture because photobucket charges and the site doesn't allow over 4.8mb pics to post.  It took about 6 hours of time, start to finish to do properly, but I like it.
Edited by DirtyMarcus
Nice setup,
Pretty sure that was the place the rough country bracket places it. But now I'm going to have to take it apart because lining it up sounds great. The light output is great where it is.
haha makes sense. You don't find it too low?
it doesn't look restricted at all. I asked my local dealer for a quote on install along with a couple other odds and ends. I would do it myself but I'm swamped at work and would like some warranty on the work and bar itself.
Looks great. Sounds like a big job to install a light bar with taking off the grill. You got great results.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,008 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
