7 minutes ago, Bushleaguechew said:
Let us know how you end up mounting that upper bar
Saw someone else, on one of the other threads, do it, just going to us his, when/if I get around to it.  Been planning on installing my front hitch during my holiday break from work, back in '14, when I bought it.  Yeah, about that.  Life keeps changing my plans and getting in the way.  One of these days, I'll start a thread of my build/mods, will post it there.
Edited by Ravenkeeper
the double rows fit nicer on the gmc grills as they are a bit wider:
Wondering how easy it was for people to feed the light bar switch into the cabin. I've seen videos where they had to drill into this rubber grommet. Looks like a pain! How did you all get the switch in there nicely??
Sent from my Pixel 2 XL using Tapatalk
I did the kicker factory upgrade a while back and I just went through the same penetration as those wires which is in that rubber grommet you mentioned. It's really not that hard to wire through. I just took a razor and cut a small slit in the grommet and then fished a straightened clothes hanger with string taped to the end of it through the firewall and into the floor board. then taped my wires I was pulling through to the end of the string that's about it. Hope this helps
Yes it does! The video i saw had the guy cutting the little nib completely off and then sealing it with some clear sealant/caulk. But you're right -- if the wires are small enough (which i think they are) it should fit with a minimal cut.
I also found this! Might be useful:
On ‎1‎/‎10‎/‎2018 at 11:05 PM, sirooga said:
Rough Country 30" Single Row Lightbar Kitfc1b53e5e180409402c245cd965b0f5d.jpg
Nice setup,
Can I ask why you chose the very bottom row as opposed tot he one above it?
I would like to go in the slotted row above it to align with the signal lights straight across.
Installed a 42" curved bar behind the grille. Took some cutting and rigging and removing the entire grille and supports, including whats shown in the picture below.  All in all there were about 30 or more bolts to remove, misc. wiring, hood latch, and headlights.  I couldn't upload a better picture because photobucket charges and the site doesn't allow over 4.8mb pics to post.  It took about 6 hours of time, start to finish to do properly, but I like it.
Edited by DirtyMarcus
Nice setup,
Pretty sure that was the place the rough country bracket places it. But now I'm going to have to take it apart because lining it up sounds great. The light output is great where it is.
haha makes sense. You don't find it too low?
it doesn't look restricted at all. I asked my local dealer for a quote on install along with a couple other odds and ends. I would do it myself but I'm swamped at work and would like some warranty on the work and bar itself.
Looks great. Sounds like a big job to install a light bar with taking off the grill. You got great results.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
