what air bag helper kit did you use, do they sit over the axle or leafsprings?
I haven't picked one up yet. Still in search of an airbag kit.
I had read that some people were getting a little vibration and that's why I went ahead and bought a 3* shim kit for the rear. Mine did not have the vibration after lowering so I didn't install them but you can pick them up at most auto parts stores, Auto Zone had them in stock.
Do you know a part number or what it's labeled as? I called my local auto zone and the guy had no idea.
Is anyone else having the low speed vibration with 2" drop shackles on their 2014? It's a very mild vibration from about 25 to 32 MPH. After a quick search, it seems fairly common on other years. I'm wondering if lowering 1" with the shackles and removing the blocks will cure it as it seems to have to do with the angle caused by the 2" shackle drop.
Also, mine is still about 1.4" higher in the rear with the drop. (2WD RCSB) I'm fine with it, but thought I would let people know for reference.
I have the Belltech flip kit for the 2014 RCSB. I have a vibration from about 25-35. Removing the trans spacer and a 4" shim didn't help much.
Belltech tech support was of no help.
Oh and I had to shorten my driveshaft 1.5", too.
I lied, they are 2* but should be plenty to get rid of any slight vibration. I'm actually going to swap out my 1.25" blocks for .5" blocks and will put the 2* shims in when I do so that I can get the pinion angle back closer to stock.
I have the Belltech flip kit for the 2014 RCSB. I have a vibration from about 25-35. Removing the trans spacer and a 4" shim didn't help much.Belltech tech support was of no help.Oh and I had to shorten my driveshaft 1.5", too.
Shouldn't you be adding another 1/2" (or more) to the trans spacer, you want to raise the back of the transmission to give you more driveline angle. If you don't have something to use as a spacer you can substitute washers or even larger nuts of all the same thickness until your vibration is gone, then order a spacer the thickness that ended up working for you. I personally would start with an extra 3/8-1/2" and keep going up from there, there should be no need to go past 1" for a drop that size, especially on a RCSB.
Just a suggestion.
You and I have pretty much the same rear set up I wonder why you are experiencing vibration I didn't add shims or spacers and I don't have vibration.
I'm not sure. I had a local shop do the install and the followup troubleshooting. We both had Belltech support engaged. I even asked if they had a certified or recommended installer I could take it to for verification of the install. No luck in all of the DFW area. :S
I didn't break open the boxes I received but they were labeled correctly. (#988). I looked to see as best I could if the install was done correctly and it appeared so.
At this point, I'm not sure what I'm going to do.
thank you.
Remove the rear blocks.
044DF323-2108-4B86-86D9-84803560B327_zps
Hello,
Hoping someone here may shed some light on a problem I have.
I have a brand new '14 Silverado 2WD regular cab. It's in the shop today getting a 3/5-4/6 McGraphys drop (kit 34170)
After installing the flip kit (correctly) there is literally no free play in the driveshaft/tranny.
After some research by my installer, and Cliff at McGaughy's, I'm being told that Chevy made a mid year change to the rear suspension and also has changed the driveshaft, new part number.
Before I have my driveshaft shortened, has anyone else experienced this problem? My truck was built on 3/08/14
Thanks.......Rich
Hello,
Thanks.......Rich
Member Bigsapper might be able to help you hes had his driveshaft shortned 1.5 in. im going to see what mine looks like i have a mcgaughys 2/4 drop kit.
Hello,
Thanks.......Rich
Yep. After the initial install, the installer didn't mention how tight the driveshaft was to install. Later when I was trying to measure my driveline angles to diagnose the vibration issue, I was attempting to remove the driveshaft and couldn't.
Took it back to the installer and we had a conversation about it. He sent it out to a driveshaft shop and had it shortened 1.5". The driveshaft has been trouble free, but I still have a vibration issue.
What chaps my behind about shortening the driveshaft, is I am planning on upgrading my driveshaft but I don't want to buy it until I get the drop sorted out.
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
