update: drop shackles installed and blocks removed. pretty happy with how it came out. some pictures make it look like the ass is lower now. see for yourself. i dont know why those pictures are turned, any info on that? haha
attachicon.gifIMG_1489.JPGattachicon.gifIMG_1492.JPGattachicon.gifIMG_1505.JPGattachicon.gifIMG_1507.JPGattachicon.gifIMG_1519.JPG
Your rear end is probably lower now, looks like it to me. Measure from ground to cab at the front and back of your cab, not from ground to fenders.
I noticed this on mine the other day after I removed my rear blocks.
yeah, it's exactly .500 inch different. I use a long solid stick, put it up against the tire to the fender, the gap on the two front and the passenger side wheels are almost the same gap, but the driver side rear have a big gap.
I've talk to my service adviser at the dealership about knocking of the leaf springs and the vibrations at certain speed. they said engineer knows about the knocking and vibration, they're working on it. but I think we need them to fix the off center of the rear axle. If everyone can check this and bring it to their attention it will help. I'm a machinist, and seeing this imperfection drives me crazy. I'm glad that my truck is not the only one.
I've read that they do this for tracking so that the rear tires aren't in the exact same tire track as the front, for better traction.
why just one tire, though? all the other cars and truck I've looked at and check don't have that.
2015 Denali dropped 2/4 with spindles and leafs/shackles and my adjustable links for the Mag Ride. 295/40/24 on 24x10 Centerline Archers
2015 Silverado leveled with Shackles and .5" block swap. 305/45/22 on Centerline Stingray IIIs
Edited by sprayed99
Hey Dan, Curious if you got this sorted out. I talked to McGaughys several months ago and they did not know when they would get MRC kits to production.
McGaughys or anyone else for that matter should say to bend the factory rods. I told Mcgaughys that almost 6 months ago. Bending the rods does not keep the same "sweep" with the sensors as the ride height changes.
Edited by sprayed99
Got mine done, McGaughy's 4/7, but I'm probably bringing the back up another inch to 6.
Looks good...but you need to pull that brake cable back a bit so it doesn't bother me anymore... LOL!!! BTW I think your right raise the rear a little, rake looks tough IMO.
RT
Edited by 07Softail
RT
Good catch! I was so worn out last night from doing the rear I just dropped it and went on. Yeah, thinking about bringing the front up 1/2" too.
Hmmm, not sure. The kit they list does include shock extenders & sensor rods. http://www.mcgaughystore.com/2015-gmc-sierra-denali-1500-2wd-4wd-2-rear-leveling-kit/
2015 Sierra Denali 1500 2wd/4wd 2" Rear Leveling Kit
This Kit Is Designed To Level The Rear Of Your 2015 GMC Sierra Denali 1500 2wd/4wd Truck. This will lower the rear of the truck 2".
Includes-
2" Rear Drop Shackles
Rear Ride Height Sensor Arms (Pair)
Rear Shock Extenders
Notes-Works With Magaride suspension
I do personally want to drop & level out the rear, but at the same time want to add bags for when I'm pinned up to the TT.
Which spindles, leafs & shackles did you use Dan? What did you do for adjustable links? Is that Denali you dropped 2WD or 4WD?
Edited by Digger3
Includes-
2WD and it is done with McGaughys stuff. The leafs are the same from 99-15. I made the adjustable links I don't know what more you want to know about the links. McGaughys got the idea about the rods when I told them what I did. The sad part is they made fixed rods which we all know the manufacturing tolerances for suspension is a joke so a fixed rod isn't ideal.
Their rods also require you to pull apart your factory rods which isn't a good idea. They are a snap fit and aren't made to be pulled back apart. The plastic end links are very fragile and I will bet they will have multiple cases of people screwing them up.
Edited by sprayed99
I just wish they would have said "thanks" for pointing them in the right direction. Back when Mike started the company he consulted with my fathers best friend on his Tri-Five Chevy parts. Most people don't know this, but Mike started McGaughys years ago from making small parts for 55-57 Chevys out of his garage and selling them off a small advertisment in hotrod magazine. I just wish his kid/s had the same values as he does.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
