So, what are the drawbacks of using rear shock extenders and stock shocks, versus installing shorter shocks?
And does anyone make shorter bumpstops that can be mounted to the OEM bump stop bracket?
Edited by Cooldaddygroove
Nothing that I can tell. I am running my stocks shocks with extenders. Rides like stock. As far as bump stops belltech and mcgaughys sell shorter ones but I don't think there's much advantage to utilize them on the stock perches bc with mine I had my stock ones trimmed as low as I could and I was bottoming hard only being lowered 4 inches. 8f lowered less than 4 inches then you can just trim the stock ones.
Mcgaughys bump stops and shock extenders
You might still have issues with the McGaughy's bump stops on some harder bumps, if you do you can look into the energy suspension ones, they are even shorter but still provide plenty of bump stop.
Shock extenders try to keep the shock in the ideal dampening range but they can also effect the geometry of the suspension and so you are possibly going to wear the stock shock out faster just for a different reason. With stock shocks and no extenders you are actuating the shock outside the ideal range it was designed to work in. Stock shocks with shock extenders helps to get it back in the ideal range but applies more lateral force to the shock because the additional angle. For what the rear shocks cost on these it is probably a good idea to go ahead and just replace them with drop shocks but make sure and read around as there are some out there that will make the ride worse.
I think the common agreed upon belief around here is that the Belltech drop shocks are the best ones for our trucks.
Edited by Darth_Vader
Depending how much drop you have, could also look into the Bilstein 5125 as they come in custom sizes and valving. RideTech has the same thing with their shocks (built by Fox) they like them a lot though. LOL
I have the 5100's on rear of mine, lowered via shackles and block removal, not using the shock extenders, I may put them though at some point
Edited by wuznme
2015 Sierra
Combination of Belltech and DJM to give a 4/7 drop. Goes back in for air assist in a week so I can still haul a race trailer (which is the whole reason I bought one... can't put a Class 3 hitch on a CTS-V Wagon.)
Looks great Croak. Nice & clean. What size wheel & tire setup are you running? Those are all terrain factory replicas right?
Thanks! Yes, they're 285/40/22 Falken Ziex tires on OE Wheels LLC reps. Couldn't justify spending 3 times as much on the OEM ones and then having to pay to strip the chrome and powdercoat them.
Edited by Croak
hey guys just picked up my 16 reg cab short box z71, looking to lower it, never lowered a truck before but i am an apprentice tech at a dealership so got all my tools needed, any kits you guys recommend? thanks in advance!
Got some OEM SEY 22" now I need to get smaller tires these 285/45r22 rub. Any suggestions?
  • Like 4
I run a 285/40/22 Falken Ziex STZ05. Toyo makes the Proxes ST2 in the same size.
I rub a bit at full lock 4/7 on 22's. I'm guessing you'll have more issues because you're an inch higher (which has you covered vertically for clearance, effectively a trade-off with my measurements) but that still puts the tire an inch further out from the hub so you're an inch closer to rubbing on the inner side of the wheel well when the steering wheel is cranked.
:EDIT: Also depends on your offset, obviously. My setup is pretty close to stock offset.
Edited by Croak
I will look in to that. Was looking at 285/35/22 but that seems too small. I see that you wrote that you rub on full lock which is not a big deal to me. Any issues on bumps?
Probably depends on your offset, I see you have OEM wheels. Mine are tucked like stock fitment and I haven't noticed any rubbing at speed but it rides like a covered wagon. I'll bottom out the bumpstops in the rear before anything touches there, I haven't managed to rub up front yet other than cranking the wheel in parking lots. Scraped the front air dam a few times.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 827 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
