Hoping for input on some options I’m looking at for dropping the Sierra.  2017 4x4 Double Cab.  Only looking for 2/4 drop.   Rear will be 4” flip with Belltech shock.  Is anyone flip kit better than another?  Come with shorty bumpstops?
McG front- 2” 4x4 specific spindle with corrective control arm ($860+/-)
Belltech- coil over drop with sway bar
Belltech- 2” drop spindle, no arms.  Includes shocks.
Any 4x4 specific input would be great.  Leaning towards coil overs but feeling like McG probably got it right with the spindle/arm combo
I have a 2015 4wd dbl cab Silverado. Currently sitting 6/11 static. 4wd has been pretty much deleted. Didn’t need it once I quit working in northern states during the winter. For what your wanting I recommend Twisted Metal Workz out of Cali... Do a Viking 0-3” drop coilover and out back do any flip you choose paired with shock extenders and a set of fox 2.0 adventure shocks in the rear. It will ride like a dream, give you the ability to go lower if you ever choose to do so.
2/4 drop. Spindle, and flip kit done.
I have the twisted metal works front coilover kit and im buying the new upper arm they make.
Reason i wouldn't do just the coilover drop is becsuse these trucks the lower you go the front wheel moves backwards into the wheel well causing more rubbing. He only wants 2 inches. Spindles wont affect that and itl keep the wheel centered
I don’t think rubbing is gonna be a factor with 2” inches no matter what he uses. I’m about to do that same twisted setup on mine with their 4 link combo in the rear. Guess I don’t think much about rubbing because I’ve already clearanced everything front and rear.
Sure is a factor. Im at 4.5/7.  Using a spindle and drop strut right now. Mywheel is pushed back over an inch.  And depending on tire size. It will rub.  It also affects caster and turning radius
When only going 2"  spindle is the best way.   I know everyone has tbeir way. But i lower these trucks for local constantly and i have found it best
Id like to see a picture of your truck from the side.
Edited by Nasty
Here ya go... 6/11
Here ya go... 6/11
Looks great but you can see your wheel is pushed back. Thats one thing when i lower these trucks i try and do it so that that doesnt happen (as much)
Thats all im saying.
I have a reklez firewall tub kit that I haven’t installed. I just made a few relief cuts and then used a air hammer to round everything out. Went over it with liner. Rubbed on bad bumps with a 295/30/24. Switched to 275/30/24 and now no rub and turns full lock.
Correct. You did good for sure. But your caster is still affected pretty greatly. Thats all im saying. If it works for you then perfect. But most people dont want to tub and do all that work. Just like me
Im going to be installing my twisted coilover kit in place of the droo strut. And im orfering the new twisted upper arm (which moves the wheels forward and corrects some caster) im also lowering it another half inch.
The wheel not being centered bugs me on mine.
Oh yea. I’m ordering that same setup from them. Guys over there are great to deal with. Good to know it will help the caster. I’ll end up setting those coilovers to go down another inch up front since I can adjust the stiffness. As you know that isn’t happening with the drop struts. Ha
Nope. Not at all raul is a nice guy. Been very helpful. I have his rear shock relocarion as well and a notch he made to my specs that still needs to happen but not for awhile.
Oh yea, he got my shock relocation from Cali to Mississippi in like 3 days because my truck was down til it got here. I used the extensive notch with crossbars and had it not been underbed notched the one from extensive would have slid right onto my frame and been an easy install. I love my fox 2.0 shocks but I can’t wait to have their 4 link with Viking coilovers on the rear.
I love Vikings. One thing you may want to do instead of getting just his upper arm is getting his whole front arm kit. Ya its more expensive but it centers the wheel at any drop and youll turn better
I’ll definitely talk with him about it. It has djm arms on it now. Can’t complain about them, but if he thinks the their lower arm will be better I’ll get those along with the uppers. Reklez has a good set of arms also. All my friends in Texas rave about them.
Oh he will definetely tell you theyre better. We have talked about the djm arms before
Plus i pull djm and inez off arms local trucks all the time. Poor design
Those are also affecting your caster and steering. Twisted arm kit is the way to go for sure. If i was going any lower id do it. But im over being that low now. Especially here in califirnia the roads arent low friendly
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
