I do love the Tungsten when it's clean but, man this color is almost as bad as black!! I wish I had liked silver better, my wife's car is silver metallic and it always looks good.
202983107357a29687c7ca77277f6ce4.jpg down loaded Tapatalk to post pictures. Bought new day after Christmas. So far roll up bed cover and tinted windows/windshield. Wish it had the 18" wheels but this was the better deal.
Edited by Ray1982
I agree , tungsten gets dirty again the same day. When it's clean I love it.
Be glad you got the 17's, the 18's come with the dreaded goodyear SRA's looks like you got some Bridgestone tires on the 17's!. I had 17's on my last truck and honestly I could take 'em or leave 'em.
Also I took off the LT on the tailgate and replaced it with a Z71 that should be on the grill68f32fac5b69285c1daab67e61cf7ff8.jpg
  • Like 4
thats pretty cool. I was going to do something like that when i do a lift an tires, though my trucks not a "true" z71
Not mine. A guy I met the other day that was interested in buying my stock rims and tires. I told him about this website who knows if he might come on down.
Edited by Silver ice 6.2
Love that color matched grill/headlight trim!
Just bought my 2016 Tungsten Metallica Silverado..Love it. Best truck I've had.
I'm online shopping for a leveling kit. Anyone have any recommendations or know if I need a 2" or 3" to stand straight with the back? Its a 2016 Silverado 4X4 LT, 5.3L if that matters.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
