6.2 Exhaust Tip?
ktreece
Just wondering if anybody has gotten theirs yet? If not make sure that they also gather your front plate filler and bracket too as it seems like a lot of us didn't even know they were missing.
Plate codes vk3 and r7e
I just posted about the front plate, if the truck was sent to a state without a front plate law then you don't get the front plate.
I still do not have the correct exhaust tip, told my salesman if I don't have it by Christmas (1 month since purchase) I would be calling GM and or having them call to get me a reimbursement check for the tip. I was billed for and have paid for the tip, either expedite it to me or give me my money back. Plain enough....
I got mine, of course its the incorect size. I purchased a nice magnaflow one and will sell this one gm gave me on ebay. Gm said the correct sized ones (3") are still on backorder.
sent from the galaxy - tapatalk
Negative on the exhaust tip. Glad you posted this, Ktreece. I almost forgot about it. Like you Tjay, if they don't provide a tip, I am going to ask for a refund through. GM.
Will
  • 4 weeks later...
I got mine when I picked up my truck. The dealer hadn't initially installed it, so I had to "remind" (tell) them that it was part of the Denali package.
Black03yukon you might want to check and make sure they sent the right one, most all of the trucks got the tip from last years truck incorrectly.
What's the difference? It fits, it's chrome, and it has GMC etched into it.
I have the 5.3L. Are only the 6.2L tips on backorder?
Hey Everybody!
Sorry to hear a few of you got your trucks without all of the necessary equipment! If there is something further you would like us to look into for you, we are here. We can be reached via PM, please include your full name and contact information, VIN, current mileage, and involved dealership.
Sincerely,
Jonathan A.
GM Customer Care
I picked up a 6.2L High Country a couple weeks ago. I just noticed it does not have the polished exhaust tip. Looks like I will be calling soon.
Thanks for the heads up.
  • 3 months later...
Does anyone know the O.D. and Length of the 6.2L GM Exhaust Tip # 23435023?
Thanks
Jeremy
Why did my question about the SIZE of the GM 6.2 Exhaust tip get moved to a section on if Denali customers received their tip?
My question will never get answered in a old dead thread.
Lol... I bet you got a PM real quick after asking this question....
Ommmmmmm.... You are in trouble!
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
