6.0l engine light flashing throwing codes! After exhaust!
Tyler Hogsten
Ok. New 6.0l motor installed long tubes 2 1/2 going to a 3in on the muffler. We'll I needed to add pipe so had to drive to muffler shop with open headers. Started it ran good no issues no light. Then oil pressure gauge stopped working assuming its a sensor. But drove to the shop ran great!!!! 12 miles or so. Then after the shop pull out on the road engine light comes on flashing. I figured it was cuz I have no o2 sensors. Added o2 sensors at home all 4. It had spots on piping that I got. But still the same thing and a ruff idle
Codes
(2) P0300 codes random misfire
P0327 knock sensor 1 circuit low
P0134 O2 bank 1 sensor 1
p0154 O2 bank 2 sensor 2
Also think O2 bank 2 sensor 1 is on there too...
Any help would be nice? Will a tune fix this? Do I need I need to space the O2s in order for the computer to read them I have no cats just resonators.
Post cat sensors are worthless since you have no cats. Have them tuned out. Did you clear all codes after installing the O2s?
There not new o2s there the stock ones that came off the stock truck (working) I cleared them and currently getting p0300 code? Ruff idle. Flashing engine light
I did a quick search on Google for "p0154", and got this near the top of results
Symptoms of a P0154 code may include:
•MIL (Malfunction Indicator Lamp) illumination
•Other codes indicating rich or lean condition may be present
•Poor idle, won't idle
•Misfire at idle or at highway speed
•Engine may blow black smoke at tailpipe
•Fuel economy may decrease
•May start and stall
Potential causes of a P0154 code include:
•Faulty bank 2,1 Oxygen sensor
•Holes in exhaust near oxygen sensor
•Short to voltage or ground on signal circuit
•Open or high resistance in signal circuit
•Wiring harness chafing/rubbing on exhaust components
•Water/oil intrusion at O2 sensor connector
•Broken lock or loose terminals on O2 sensor connector
•Oil/coolant fouled oxygen sensor
Have you tried searching the trouble codes? This one in particular has very easy to locate information. I did not try the other codes you listed. If I were you, I would search all codes you are getting, and find the common ground between them.
I understand and had narrowed this down to the O2s since this hasn't happened until the exhaust was put on. I can't figure out how to get the computer to read both Front O2s do I need spacers? I can delete the back two. Worried up the miss fire and knock sensor which Is possibly the issue of the computer not reading the front O2s and throwing the mixture in wack...
If you used to have 4 sensors, then there was 2 upstream sensors, and 2 downstream sensors. Upstream usually means ahead of converter, and downstream usually means after converter. The effect is the PCM can see the converter working. Are you sure the sensors are connected to the correct connector?
Yes. I can try moving the down streams down the exhaust winced there's another hole it can go in. These were made into the exhaust. Yet the computer can't detect the O2s?
Do you have a scan tool that can read output values for various sensors. I am fairly certain that the PCM monitor voltage from the actual sensor and does not depend on there being a difference in the two readings to prove existance of o2 sensors.
How far was the exhaust shop from where you did the work on your truck? Have to wonder why the light did not come on during the trip. Have you also verified that when you changed the engine, you did not trap some wires or route them too close to hot parts? You will want to start looking at the wiring harness looking for spots where it could short out.
Ok. So I cleared the codes and move the sensors back.. And no O2 codes came in!!! :) but... Two p0300 random misfires came in... So I'm gonna pull the truck in the garage cuz I'm cold... Dang MI weather haha. It was warm yesterday! We'll I noticed one of the spark plug wires r rubbing the headers.. Gonna zip tie that up. And tighten all exaughst bolts to stop the exhaust ticking from small leaks.
To answer your question I do have an advanced scan tool. And I drove around 15 miles to the shop on open headers. 55mph roads.
Also the engine lights still flashing
We'll I did some searching and I'm going to see if my scan tool and see if I can do a scan relearn.
I didn't do a crank relearn. I replaced the wires do to the two rubbing. Put heat selves and wrap on the wires and no codes! Rolled over 73 miles ran great! Then today wanted to put some miles to make sure everything's all good and not even 3 miles down the road engine light. ANOTHER p0300 code! And two knock sensor 1 bank 1 codes.... Wtf? Any help here? At least it's not blinking...
I know with mine I was able to run a misfire log. Depending on scan tools available to you it can be done and pin point it
Ok drove 200 miles and only engine light.t I get is two codes... Their both the same. (bank 1 low circuit input).... I deleted the codes then they came back on... These sensors are a year old... Same with pig tail and have been siliconed in.
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
