just ordered this from Autoaccessoriesgarage.com for 101 with free shipping. can't wait to get it installed, thanks for the great thread.
I am just curious is the new cam arm really needed?
Yes, it is. Mine had a slight burr on it, which prevented it from going on to the shaft properly. Had to bust out the grinder and clean it up, then it fit just fine.
Does anybody know what gauge the wires are that we're tapping into? I want to get the right size posi-taps. Thanks.
I'm 99% sure the kit comes with the wire taps. I'm not fond of them so I stripped off about 1/4" of insulation
and soldered the wires in place. I have had problems in the past with wire taps on small gauge wires.
Whether you solder or wire tap, make sure you stagger the connections so you can get the cover for the
wire channel back on.
Thanks. My understanding is that what comes in the kit are ScotchLok, which nobody likes. I'm no car electronics expert but have used posi-taps in the few projects I've done without any issues. Though maybe it's time to finally suck it up and get a soldering iron and learn how to solder.
Edited by BigRedd
Thanks. My understanding is that what comes in the kit are ScothLok, which nobody likes. I'm no car electronics expert but have used posi-taps in the few projects I've done without any issues. Though maybe it's time to finally suck it up and get a soldering iron and learn how to solder.
I've always used ScothLoks with limited success. I'll have to check out posi-taps.
If you decide to solder go with a cheap Weller pencil iron or a Weller gun kit from Lowes, Sears, or Home Depot.
Get some smaller diameter rosin core solder and you are all set. I think the gun kits come with some solder.
I have a Weller gun which I usually use for automotive soldering but it has a messed up tip and I used a pencil
iron for this install. Gun is almost instant heat where the pencil needs to heat up and you need someplace to
sit it down where it won't melt anything including it's own power cord.
The wires are either 16 or 18 gauge. Hard to tell with variable jacket thickness.
I've used every type of wire tap on the market, they're all mediocre. If you want a solid connection, solder and shrink-wrap it. I'm not terribly concerned because taps fail when excessive motion is involved. That wire bundle is zipped and bundled down real well. I used the provided taps without any concern. It's not exactly hard to get back to it if I needed to, although I highly doubt I will.
Just for fun I called Ziebart (leer Dealer) where I am getting my cap from and they will sell and install for $89 bucks.
I just completed the install. Thanks to everyone who contributed to this thread. My install took 1hr 20min, a bit longer than most on here it seems, but the aircraft mechanic comes out in me whenever wiring is involved. It went extremely smooth and I chose to solder my wires to the factory harness. The only hiccup, if you want to call it that is that the lock did not want to unlock with the FOB. I attributed it to the truck being new and the parts just not "worn in" on the whole mechanism. A quick shot of ACF-50 cured that. Thanks again everyone!
I installed the the kit yesterday and everything went smooth except for one thing. When locking with the key it seems like you need to turn the key just right to get the handle to lock or unlock. My question is should the new arm that comes with the kit have free play? If I turn the key and hold the arm there is movement but there is drag on the arm. I'm thinking that the arm should move freely. Yes, the C clip is pointing toward the hinge as described here.
Thanks in advance..
I installed mine this week. It took a few hours, but I work slowly. Big thanks to everyone who contributed to this thread. The tips helped me to avoid any issues. Thanks to fondupot for the video!
Edited by Kilo-9
Gonna pick one up and add it this weekend.
Worth it. Best add-on mod. Mine is still running perfectly, I have zero complaints. I also did some extra work and plastic-sheathed the entire cabling up the frame and wrapped that in electrical tape, similar to stock. Also, get some extra zip ties. A lot. Don't cut your wires until you've completed the run entirely. It's real easy to accidentally cut too much.
I haven't read through all 11 pages of this forum, but I did find the diagrams and instructions very helpful, with one additional point of clarification.
There are TWO gray wires (without stripes) on the 2015 GMC Sierra 1500 SLT Crew. One is around 20-22 gauge wire, the other is around 18-20 gauge. The one you want is the thicker of the two. It may be buried in the bundle of wires, just keep looking for it.
If you want to be sure, use a computer safe circuit tester. Unfortunately, I didn't have one on hand, so I learned the hard way.
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
