I really want to do this, but I'm nervous. This sounds slightly out of my comfort zone, although I am really handy. Is it really that easy? This forum is simply incredible. I have already done and learned a ton about my truck from you folks. Great community. I've been on a lot of forums for various topics, and this is certainly the best one I've been a member of.
The tailgate part is pretty easy since it is just unscrewing a bolt and replacing the lock lever.
It takes some finesse to get it to move smoothly so you may have to play with that a bit.
The running of the wire to the front requires getting under the truck and zip tying along the way.
Connecting to the correct wires, and what approach you use will depend on your experience.
I am comfortable with soldering so that was my method, but the kit comes with slide on connectors which are easier but may not be as secure.
Fondupot's video is a good resource.
Edited by crewl1
Thanks man. I'm actually pretty good at soldering - my Mom used to repair computer boards when I was a young buck, and when she got behind at work and had to bring it home she used to let me help her. If it's just running the wires down along the bottom of the truck, that doesn't seem too bad. I'd be more nervous if I had to pull up interior pieces to route the wires - that's where I get nervous.
The mechanical install in the tailgate should be no issue for me.
I think I'm gonna take this on. I just picked up a tonneau and really want to to be able to control the lock with my fob.
Oh yeah you should be fine.
A tonneau was the same reason I wanted it as well.
The only piece that needs to come up is the door sill and wire cover underneath.
Take your time on each tab on the near side.
The opposite side are the same tabs but once one side is up the other side is easier as you are then just shifting the whole piece towards you.
As others recommend stagger the location of your solder joint to each wire so you don't end up bulking up that spot, the wire bundle is already jam packed as it is. (May be more of an issue for those who use the included connectors.)
Good luck!
Edited by crewl1
This mod is very easy...just time consuming. Took a while to run the wire from the back to the front.
You can squeeze the wire in with the parking brake cable without having to cut the grommet on drive side where it comes through the floor.
Here are some pics of my tailgate, I had the retainer clip in backwards at first then rotated it and it works fine now. I tried to get a good photo of it.
Also, did $0.75 mod so reverse lights come on with cargo lights...all LED.
Edited by rdtpp1991
  • Like 4
Just started my install today, and completed the tailgate hardware install. Easy-peasy. Waiting to run the remainder of the wiring until this weekend, as (a. I'd like to have daylight on my side, and (b. I ordered the dressier door sill plates for my truck, so they'll go on when I pop the driver's sill to wire this up.
I do have to give thanks to everyone who's created a walk-through/ video/ photos clarifying the installation...the Xeroxed b/w instructions don't have the best detail right out of the box, so these have helped considerably!
I've been loving mine. So nice knowing its locked when the doors are locked. No more going back to make sure I have it locked.
As I work at a college and unlocked vehicles get targeted.
Of course being in I.T helps as the new HD security camera's just happen to point right out to where I park. he he..
Do it. Finished it up the other day, and it's so worth the $90-100. "Hardest" part was running the wire along the truck, crawling in and out constantly. I'm not usually big on the scotchlocks, but got them to work with a firm squeeze from pliers and then wrapped in duct tape. Even managed to to get them tucked away and not prevent the covers from reinstalling properly.
When I did my alarm mod I revisited the Pop n Lock and found that the reason the mechanism can be sticky is that the replacement plate is too thick.
By shaving it down a hair (I used a Dremel with a sanding drum) it now swivels freely with the C clip attached.
This free movement is needed so you can lock and unlock with the key and return the key to the center position without disturbing white locking mechanism.
(Here is a link to my alarm modification that leverages the locking tailgate in combination with the factory alarm.
Anyone order a pl8140 kit recently. I ordered the kit from amazon for my 2015 and it came without a new cam. Sent it back and received replacement today again without the cam. What gives?
Sent from my SM-G920V using Tapatalk
I had the same problem the first one I ordered from Amazon did not have the cam. I called Amazon and they sent me out another one the same day and it had the cam. One of the Amazon facilities is about 30 minutes from me.
I had the same problem! My lady got me one for xmas and my folks did too. I planned on returning one but when I went to install it today neither of them had the pop and lock cam! I emailed pop and lock and hope to hear back from them when they return to the office on Monday.
I did hear from them and they had a manufacturing issue where kits went out with no cam. They sent me out a cam promptly no questions asked. Just get the cam because your rolling the dice with amazon.
    Chris80s
    Chris80s
  • Who's Online   4 Members, 1 Anonymous, 688 Guests (See full list)
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
