The "E85" Ethanol Topic
OUSux
Whats the self life on E85? I found one place in town that has it not sure many buy it here.
  • Replies 70
Never run it in mine. But I'm curious about the power improvments...gotta try to find a station with E85 now and do a few tanks worth.
The power gained isn't worth the drop in mpg to me.
It is cheaper but my mpg seems like it almost gets cut in half. For me it cost way more to run E85 and I'm not racing my truck so I don't really care about the hp.
I tried searching, but didn't find any results. Anyone here know were the price point is where E85 is an advantage/disadvantage price wise?
I posted on the chemistry of E85 previously:
http://www.gm-trucks.com/forums/topic/156625-e85-fuel-economy-in-the-toilet/?p=1392701
To be clear, unleaded can mean anywhere from 0-10% ethanol. I'm assuming you're not talking about ethanol free (E0), and you are talking about 87 octane E10 (most common/cheapest). On a btu/gal basis (what you pay at the pump), E85 has ~26% less energy content/gal than E10. At $3.30/gal for E10 87oct, this would require E85 to be $2.43/gal or less for break even. A data set of real world comparisons would be a better tool, but this estimate is based on chemistry.
It depends on what you're averaging MPGs wise. Here are my numbers.
Using regualr unleaded, I am averaging 15.3 mpgs. Using 24 gallons as a baseline fillup, that's 367.2 miles to the tank.
My last fillup was using E85 and I'm averigng 13 MPGs, so with 24 gallons that is 312 MPGs for a difference of 55 miles less on a tank of E85.
Those 55 miles divided by my average of E85 is 4.2 Gallons (55/13). So it would take an additional 4.2 Gallons of E85 to equal one tank of Unleaded using my averages.
Right now E85 is close to $1 cheaper a gallon ($2.64) than Unleaded at ($3.57) at the gas station I normally go to
So, 28.2 Gallons (24+4.2) at 2.64=$74.49 for Ethanol
24 Gallons at $3.57=$85.68 for Unleaded for the same miles per tank.
Even at the lowest price in the area for Unleaded:
$3.40x24 Gallons Unleaded=$81.60
E85 seems to be more stable in price, with gas fluctuating as of late. To keep from having to recalculate every time I fill up, The 20% rule seems to be close; therefore E85 needs to be about 20% cheaper than Unleaded to make it worth it. For my last fillup 20% of $3.57 comes out to .70 a gallon, which the price I pay locally far exceeds that.
I'm going to reassess after my next tank. Sorry for the long post, but I wanted to use real numbers.
I did some testing back in 2012 and figured 70-75 cents cheaper was the break even point for me too.
Also, this:
http://www.fueleconomy.gov/feg/bymodel/2014_GMC_Sierra.shtml
Government seems to agree/admit to the ~26% mileage reduction. E85/Regular for 5.3L 4WD ---->> city 12/16= 75% hwy 16/22=72.7% combined 13/18=72.2%. average all of those because not enough significant figures (no decimals provided): 73.3% or a 26.7% reduction according to EPA. multiply your 87 octane price by 73% and that's what the E85 price must be below to break even. at $3.50 a gallon thats about 95cents
I just filled up with E 85. I'll see how the mileage works out. I see another possible long range benefit in that it should run cleaner, thus result in less contamination to the oil. If it generates less heat and contaminates the oil less it might prolong engine life. While the plugs last a long time now their life should improve too. It's supposed to raise my top horsepower by 25 to 380 and increase the torque too. That's got to be worth something. The biggest downside is that it isn't practical for long trips, at least in my part of the world.
not sure what burns "cleaner" means. EtOH has no sulfur so no SOx emissions, burns cooler so less NOx, but increases many other tailpipe emissions like formaldehyde, acetaldehyde and methane.
http://www.afdc.energy.gov/pdfs/technical_paper_feb09.pdf
There is detergent/additive added to petroleum fuels at the pump, multiple O2 sensors, engine knock detection, etc. now that incomplete combustion and coking doesn't seem that much of a concern relating to spark plugs and engine gumming. If GM engineers were worried about burning cooler, they wouldn't have designed a DI 11:1 compression ratio engine i would imagine either. The HP bump is apparently from the way EtOH burns throughout the entire piston stroke, rather than just at the top of the stroke. If you need the HP increase, go for it, it just comes at a sacrifice. The downsides of EtOH are the added cost to make your vehicle capable to handle corrosive alcohol, EtOH affinity for water, especially in a large vapor space (empty gas tank), and energy dilution. thats before you get down the rabbit hole of how inefficient the whole process is. If you role in the tax subsidies to the cost of ethanol/gal it would be totally obvious its not economical, or ecological.
All true, any actual gains outside of performance are minimal if any. By the time you figure in the fuel consumption rate for E85 vs Gas, the carbon foot print will be the same, maybe even worse. I hate trees anyway, always screaming at me and pointing and laughing. Almost made me stop doing acid once.
Also takes ~700 gal of water to raise a bushel of corn. 3 bushels of corn to produce a gallon of ethanol. Plus the energy to plant, irrigate, pick, transport, and refine. Add to that the water used in the refinement process. Anyone who tells you you're helping the environment by running corn based ethanol is a complete idiot.
Not to mention it was brought into use by politicians to buy off farmers who are too lazy to adopt sustainable farming methods.
But if you like the way your truck drives on it... Go ahead.
Excellent post.
  • 3 weeks later...
I hate that crap.... If they sold it for 2.00 a gallon that's one thing but when it's subsidized by the government and selling near the price of gas? No thanks
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 800 Guests (See full list)
    • When I bought my 14 GMC I turned it off with an handheld programmer. With my 16 Odyssey I left it on solely because I didn’t have much money in the vehicle. There’s a device to turn it off that’s a little more involved. The GMC at 72 MPH the deactivation was on very little the deference was 1/2 mile per gallon. The Odyssey is on over half the time at 72 mph.
    • Anyone ever thought about switching the interior door panels from the base model to the Denali style? I’ve seen that you basically have to cut, sand, mold, paint, the window switches together to get the look right. Is that the main reason people don’t bother doing the swap? Seems like the only method that is easy I guess, without having to mess around with wiring and stuff.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
