I just used some rubber cement glue on the seals. I folded the buckle straps in half so the plastic buckle no longer rattles against the cab, but they still sit flush between the cab and bed and are mostly out of sight.
if anyone in Ontario Canada is looking for a short box soft trifold cover (has Chevy logo on it, direct from the dealer) i have a buddy who traded his 14 short box in for 14 reg box box and is looking to sell the cover.
i dont know what he wants for it but i can get you in touch with him.
I'm looking into glueing the front corners too. Got a brand new hot glue gun, and haven't had anything to use it on yet... :) I do see a big deal in having to re-engineer a product to work as intended. Small leaks are OK, this is a major hole. I still say a cross member holding the cover tightly at the front with proper seals and hard strap buckle mounts (the buckles rattle like crazy between the bed and cab.) would be a 1000% improvement in this product. I hope they continue to improve, maybe on version 3 of this cover?
I also thought about covering/blocking the release cable. Probably do exactly what you suggested with the metal bracket. Thanks.
I installed the same cover on my 2014 Silverado regular bed 3 months ago and love it. I used the weather strips in front and all I get is probably a few ounces - enough to make a very small puddle near the front corners after I run it through the car wash or after a really heavy rain.
The cover settled completely flat for me after a week or so in the hot sun. The only complaint I have is that when I go to roll it up, it sticks a little unless I manually push up the stops by the tail gate, one of these days I may get around to re-aligning the cover, but for now, it's no biggie.
Ordered my High Country with the Factory Folding Hard Tonneau cover and so far I'm very happy with it. 5ea3b8a1adae98789cf7233e87af24c8.jpg
I like that one. Seems like one of the pricier ones though!
It was 925 installed plus tax locally. The other models are only 200 less, that's not a whole lot when you have a 30k truck. Do it once do it right.
Also the reason I chose the HD over the g2 due to it having quite a few features from there flagship f1 model
Super happy about my purchase.
Fair enough.
Just picked up my new 2014 Sierra SLT Double Cab in Quicksilver so it's a 6'.6" bed. My first post and brand new to these boards and new to GM trucks. I have read 25+ pages on this tonneau cover thread and am stretched on the purchase of the Sierra and want to get a tonneau that fits comfortable but fits the budget too. Please help me force rank the following:
TonnoPro soft (item# 42-108) $269.00
Tonno Pro Hard (item# HF-158) $529.00
Extang Hard (#56445) $646.00
Extang Trifecta (#44445) $334.00
Greatly appreciate the input/advice.
It all depends, how much does security matter to you? I have heard a lot of people having issues with the hard extang leaking. The tonno pro hard is a bit clumsy to latch but, the one piece top layer helps keep water out I'd imagine.
I pulled the trigger on the extang soft. Security does matter to me but it isn't really an issue when factoring in the decision. Thanks for your reply by the way!
I have the Extang Full Tilt. 3rd one I've owned. I had this same cover on my 09, 13 and now 14 trucks. Opens like a hardshell, you can roll the tarp up like a regular soft OR the entire frame with tarp in tact can be removed in less than 30 seconds. Very slick cover and I highly recommend it.
Since i just picked up the soft Extang Trifecta...but I never researched how these soft covers hold up in the snow. Then I noticed the Extang manufacturing site is Ann Arbor Michigan so I am guessing the developers took northern winters into consideration. Any real world experience out there with soft covers and accumulated snow???
I have one on my 2013 and am putting one on my 2015. Great product no issues last winter and it was a record winter
Thanks...I was hoping to see a reply like this!!
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
