Love the RB10's!! Def. what I plan on putting. Could ya post up a couple more shots, different angles?
Wanna see the whole truck too, looks good!
Welcome to the forum...
Edited by Nolasaintz
You'll like the RB10's! Just be aware that they have a heavy texture on them that holds dirt. I love mine. They do a great job at protecting my doors, rockers, and even the box side in front of the rear wheels!
I really like my RB10s
Ive had em for a few 1000 miles on my '15 GMC Sierra crew..
Got a good lead on some amps I cant pass up so probably selling mine.
Im in Austin.
If anyones interested.
I am thinking of getting the Steelcraft 4" Premium Oval Nerf Bars in stainless steel and I was wondering if anyone else has installed them on their truck. I have looked thru this topic and searched the site also and didn't see where anyone has posted about them. I was also wondering about the quality of Steelcraft products and their durability. Thanks.
just bought the Ionic Voyager Running board - 6" - I am the least mechanically inclined person on this board and I was able to instal these in 1.5 hours. Look just like OEM.
Get the Raptor stainless ovals ... many folks have posted excellent results and confidence in them on this forum ...
I have WeatherTech mud flaps installed on my truck and I was wondering if the Raptor OE Style Oval Nerf Bars will hit the mud flaps or if the will clear them without any problems?
We have the factory mud flaps that we installed on our 2500 and the Raptor stainless ovals allow sufficient fore and aft movement / adjustment to clear them ...
Is anyone interested in tradeing thier oem black steps off of a 14+ for my oem stainless/ chrome located in southeast Michigan thanks
Edited by onmytab
I will be selling my factory chrome 6" steps soon if anyone in the Atlanta area wants to buy them. They are coming off my brand new Denali to make room for AMP steps. PM me if interested.
Edited by Davidpsalt
Post them in the for sale section (remember they fit multiple years) and in your local Craigslist. Sold mine in 1 day!
Edited by chuckl1218
I think I have narrowed my choice down to either N-Fab nerf bars or Lund International Rock Rail Gaurds. I use my truck off-road so the stock running boards I have now are getting in the way. At the same time, I can't get rid of them altogether because my wife is 4'11".
Does anyone know which of my two choices can take a bigger beating and are more out of the way? I understand they are both body mounted which might make them close to equal. If it matters I have a double cab Z71 at stock height but I plan on a 4.5 or 6" lift in the future.
Edited by PN4
RB10's on my CCRB
Do you mind posting a picture down the side of the truck to show how much they stick out? I ordered these yesterday and would like to know. Thanks!
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
