subscribed for new console plug situation .... :lurk:
so far for me this would work since i have the 110v up front and the 12. just run the 12 from the rear up front to the second.
i did read somewhere someone was going to check on the wire harness that doesn't come with bench seat trucks (front harness i believe) for proper fitment.
can anyone with a console truck check under the dash next to the parking brake there is a black box. if you open that and see if the bottom left is empty, mine has an empty. wonder if the wire harness the bench seat trucks are missing goes in there? i know one of those plugs are live wire. would make sense for the 12v in new console.
i guess that could always be used to power the third 12v of the new console
For those who've got this done, once u reconnect the harness for inside the flip up plugs, does the light work?
Some of us who have the console have also purchased the console insert to help manage that big space...
Posting for updates. I should've dished more money out to just get it the way I wanted before... *Sigh* Lessons learned.
Can someone tell me exactly what the 4 part numbers are? I know the "console" is the main part but what are the two "plates" and the "panel"?
It should be these posted previously. I think the panels are the sides of it where the trim is located.
Console gm# 22995069
Panel gm# 22817349
Panel gm# 22817347
Plate gm# 22995085
I have the part numbers just wanted to know what the parts actually were. I find it weird that if the panels are thr silver trim that run along the side that theyre 2 different prices
another question, the part numbers provided are for the silver painted trim? Anyone know the other part numbers for the different type of wood grain offered? I need the lighter wood with black interior.
Looking to do this on my crew cab sierra. Do either of the front seats have to be removed? How long was install time? Hopefully someone can find the correct wiring harness for plug and play. Thanks
The panels are available in black and cocca. The plate has about 10 choices, depending on color and options. The part number listed above ( 22995085 ) is "Reverse Tartan" what ever color that is. The panels listed above are black.
Edited by tbarn
Thanks tbarn. I guess ill look to see if they offer them in the aluminum color or just get the part number for the light wood color.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
