That Pearl white looks awesome against the snow's white. Killer wheels too!!!
I would like to get opinions on leveling kits. Specially GM-sanctioned ones that won't screw with my truck's warranty. Please ?
GerryLP :cool:
Anyone have experience with the diodedynamics.com HID kit for 2014 sierra? Listed for $150, not bad.
Sent from my iPhone
Custom brackets for rigid dually d2's. These guys are willing to do full on CNC aluminum brackets that will look much much better and be all 1 piece! These are adjustable too.
Are the brackets from rigid or elsewhere? Thanks.
They are from a fab shop here locally. Wasn't a fan of the rigid ones. This fab shop is willing to produce these if enough people want them. I think they are much better looking than the rigids.
Can they fab some up for a silverado to house the same DOT lights?
Count me in for a set. These will fit both Silverado and Sierra correct?
Sierra fogs are more square while the silverado are more rectangle. But I'm sure if enough people either side sierra or silverado these guys will do it. They do some solid work. These guys built my 1000 for me which is attached.
Got my truck back from the body shop .
I now realize that I didn't take a picture of the damage to the hood, but it's smooth now.
And, the day I got it back:
I still need to get around to fixing the grille. I have the two pieces that broke out of it, I just don't have anywhere warm to do it (Glue doesn't work too well in -33 C). I may end up getting a new grille for it eventually, possibly a High country grille just to change it up.
I also had an idea about taking the black/chrome bars from a GMC All terrain grille and seeing if I could mount them in a chevy grille like this:
Anybody with an AT grill think this is doable? It would take a lot of cutting and cobbling together, I likely won't try it unless I can get one for cheap.
Edited by jonny24
I know realize that I didn't take a picture of the damage to the hood, but it's smooth now.
I actually haven't thought about doing that to a Chevy grille. But, my personal opinion is that it doesn't go that good in the Chevy grille like you have it in the pic. Maybe if you took an aftermarket grille for the Chevy that's open without the middle horizontal bar and then put 2 or 3 of the A/T grille pieces like you're thinking. I love my Z71 grille so I don't plan on replacing it or modding it at all.
bf9f19b44a8f4ada5e0666ec586a9402.jpg I did a mod to disable the amber parking lights with a switch, while I was at it I added led lights on top of the grill facing down, also powered by a switch.
Did some colormatching tonight. Will post up some more pictures in a few hours after everything is fully dry and reinstalled[emoji106]
A1FFA099-3552-4D16-9745-2F5876EBA014_zps
BTW, to remove the small aluminum trim piece around the radio control knobs. It's not a difficult process, but a tedious and very aggravating process
C29B2889-A24D-4ED6-8FCA-C88BE225F3FB_zps
You have to completely take apart the trim that it sits inside of.
Your a Brave Dude!
Your a Brave Dude!
You mean for taking apart the screen? Oh believe me, I cringed every time I turned a bolt. Only used a screwdriver. No way I was gonna use any kind of power tool on that thing.
Is the newly painted surface smooth like the silverado's trim or rough? Are you matching it with the other trim inside (console, door trim)?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,355 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
