Did you tint the lights yourself? If so what did you use? If not, who did you have do them?
Body shop at the the dealership I work at did them taped off reverse lights and sprayed black and clear coat 7 coats I believe still very visible at night.
Put in my new LMZ LED 5000K headlights. Damn this SOBs are bright! And I don't even have them properly adjusted yet (inside the projector I mean. I'm not talking about having a high cutoff line) so I think they will work a bit better once I do so. I highly recommend these to anyone who's looking to upgrade to some useful lights!
Don't have any pictures yet though. Will get some up soon.
Cleaned her up and removed the front air dam.
Lookin good.
I might have missed it but what size tires you running? Wheel offset?
Lookin good.
Tires are 275/60r20. Wheels are XD Addicts and are a +18 offset.
Adjustable brightness for footwell lighting!!
Edited by morrislee
Finally got around to installing LED back-up lights in my Sierra. They make a WORLD of difference (I can actually see things now! :-) ) but in the process, seem to have killed two of my brake bulbs. One still has the tail filament working, the other went from that to completely dead. Not sure what exactly caused this, but since 7444LL clear bulbs seem to be hard to come by, I need to swing by the dealer tomorrow (and ignore the "turn signal failure" messages when changing lanes). :nonod:
Put up a new carport to keep it out of the sun/rain/hail..
I went straight from a 98 Silverado to my '14 and seeing that pic just made me realize how much bigger the K2s are to the GMT-400s. I honestly don't notice the size difference while driving, but maybe that's because I've always had fill size Chevy trucks lol.
Ordered some fender flares. But I'm not sure I made the right choice on brand. Anybody have any experience with bushwhacker or rough country?
Well from what I seen, most trucks from factory get bushwacker, but I wouldn't pay that. I rather get the knock off brand Lund for half that price, they fit the same purpose and look the same.
Replaced a water pump in an 05 Trailblazer with a 4.2 I6 for a coworker after work. Wasn't too bad but nothing near the ease of a water pump for my LM7 5.3L. Made $75 as well [emoji106]
I put gas in the Sierra. Cheapest fill-up in a while since I didn't have to put 93 or diesel in it. :driving:
I'll probably get flamed for saying this but IMO, I wouldn't do bushwhacker or rough country. I personally think that they look more like an after thought rather than a quality OEM kind of looking part. I personally think that the flares from Southern Comfort Automotive are the best looking flares for these trucks. The flares look almost factory because of how they sit on the truck. Maybe its just me but my vote always goes to SCA flares for these trucks. I plan to get some for mine after I lift my truck so I don't destroy the paint on the sides.
I'm not saying that the SCA flares look like they are a factory option by any means, but I do think that they look like they had more thought put into the design to stand out and be bold and completely change the look of the truck
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
