Anyone know what colour wire the dome lights might be? I'm hoping to tap into it so I can add some lighting for when I open the doors. This is the best I could find, and I'm still a little confused.
http://www.silveradosierra.com/electrical-manuals/2014-silverado-wiring-info-t228266.html
NitroDatsik? You're kinda the lighting guy, maybe you can help me out. Thanks.
People are tapping into different spot same wire. For me (bigger guy) was easier to tap into it on the driver side pillar. If you pop it out there's a bunch of wires. There's 2 solid greys, one is thicker and that's the one you need.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Nitro
What type of entrance lighting setup were you thinking about?
Sent from my SG Note 4 on Tapatalk
Nitro
I use some cheap waterproof lights from Amazon. I think I paid $8 for 4 and 2 of them have been good for over a year. I had replace the 2 on the driver side. The only thing about those led lights is the wires are so think you need to be careful not to break them.
DROPKICK Edition
Jlm
First off nice truck, second is that a Sierra or Denali? And lastly, how did you go about mounting those LED pods? Very nice addition
Thanks. It's a Sierra 1500 All Terrain.
Which pods do you mean? The hood ones are mounted to a T-Rex bracket. The fog ones are mounted to a Rigid Industries bracket.
Josh
What color is that again? Hope its still available on the 16's...
Stone Blue Metallic :)
Josh
Is the grey wire positive or negative? And that's for the dome lighting right? I just want to make sure, I don't want to have to do it twice. I'm gonna add footwell lights, as well as door lights. Footwell lights just like the ones from the very first post.
Sent from my SM-G900W8 using Tapatalk
I got my new Tonnopro Lo Roll tonneau cover installed. I'll post some pics when I get some better light. Also have a bedrug coming tomorrow. Cannot wait to get that in my bed. So looking forward to camping out of the back of my truck.
Awesome buddy! Glad u got the tonno!
How much was ghe bedrug? And where did u get it?
Edited by dbcooper748
Any more info on that led bar looks like db link correct me if I'm wrong looks f bright.
Update : nvm just saw its a cree 32 looks good btw
Edited by Gmcant33
Well thanks to that fun storm that came thru last night I lost my headlights. Everything else is functional except for lows and highs. Looks like its time to go buy another hid kit.
Ditched the 305/55 idea and went with 305/50. That's a one inch difference and it makes a big difference. I'm going to finish it up tomorrow, but here's what she's looking like right now. 20x12's on 305/50r20 Toyo AT2's 2.5" Level.
& a comparison of the new setup vs stock with 2" spacers
  • Like 4
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
