Wasn't today, but Installed the motofab 2 inch spacer and the 2 inch rear block over the weekend. If I ever wash it again I'll post pics.
Love how it looks, just to short from the factory.
I went with Kings from AutoAnything and beat MRT's price. Let me know if you need a contact there.
Yeah if you can shoot me a message with any info i would appreciate it
Looks great! whats their email? I tried emailing them about a month ago two times but haven't gotten one reply. I want to get fox coils too but might just go with King coils if i can't contact them
I went with [email protected] but try this one, [email protected]
Drove to ohio to meet another member this past weekend and do a front end swap. He had all his parts painted for me before I got there since his truck was red. The grill was an absolute nightmare to take apart but it was 100% worth it.
Grill was a pain to remove? I thought it was easy. Did you have to do something different bedsides the 4 bolts on top?
I'm sorry I mean it was a pain to separate.
Washed Truck - 4 July 2017
IMG 0071
Washed my wife's CR-V and my truck this morning, before it got too hot. Was 68ºF at 0545 when I started and 92ºF at 0900 when I finished. Her CR-V really needed it, looked like it hadn't been washed since we bought it. My truck hadn't been washed since about a month ago, when I got the oil changed in it.
Edited by Ravenkeeper
Traveling to my grandparents today for the holiday & spotted this at the dealership. Wish I had one, so wicked.
Installed under hood lighting! LED kit from diode dynamic, pin switch for auto on and off. Will get better pics tonight ;)
  • Like 7
Does it make it well lit to work under the hood?
I think it will yeah, I will post some more pics tonight when it gets dark.
Painted my skip plate d210fd64ac21ac6539decaa4adbae3ac.jpgee629bd2068c98eef38c18b40f75e322.jpg
Did my dash properly this time with plasti dip not wrap 8ab3335f82359ff5d911b4f5fcd13931.jpg
Also got all my led tails set up, pain in the butt post pictures later
Edited by SuperSierra
Nice! Love the painting idea, what color is your truck?
Stone blue with red detail, superman themed sorta 5aa5ec2fc5a4398e21caf22c8bb42404.png
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
