Well finally took the plunge this morning and knocked out my color match. Bow tie comes in on Friday.
Just got the bumpers left. Pics below are when I picked it up from the dealership and this morning after the install.
Looking good!!!! Is it a wrap or paint?
Had to paint.  First I had to obtain parts that had been painted/primed already.  Then sent them off to get painted.  Finally reinstalled.
I'll get a good picture in the sun in a couple days.  Deep Ocean Blue Metallic.
Looks great man. I would leave the bumper chrome, kinda like the High Country.
Thank you.  I've been debating whether I want to do anything to it or not.  I plan on leaving it like this for at least 6 months.
Way easier on the rock chips!
From the black Friday sale, I got new rotors and pads from Powerstop.Got them installed today and hopefully broken in correctly. It was raining here and I followed their instructions. The truck stops. But the problem from the factory brakes I had was when getting off the interstate, it would shake the whole truck. I shall find out tomorrow on my way to work.
I did my headlight trim and grille. I left the bumper chrome. I actually like the look a lot better than having the bumper painted too.
I finally finished up the install of my JL center console stealth box. I have not disabled the active noise cancellation yet but I have yet to drive the truck with the sub working. So far that little 10 hits pretty good.
On 12/5/2017 at 6:28 PM, RocNYRunner said:
Put the Christmas Lights on!
This is the only time I wish this truck had a roof rack.  :)
Curious how you wired those up?
Straight forward job?
Got my truck back from line-x. Had the full undercoating & rust remedy done. Also installed the rear air bags a couple weeks ago. 35c5933c971f5df8c46d84b7751ad9c3.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
The only thing that tripped me up, was I did not spot the screw that held the rotor on the front. There is a small torx 30 size screw holding it on. When the rotor did not jump off in my hands I bumped it a few times with a dead blow hammer. Still no movement. I then looked closer and found the screw. Other than that, I had to locate torque specs on this forum. They work great and are smooth!! Happy with that for sure!
Glad to hear. I’ll be changing the brakes myself soon for the first time on the truck and on any vehicle for that matter
You're probably hoping for something cool, but in reality...  It's just an extension cord in through the back door, plugged into the dash.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
