18 hours ago, JimCost2014 said:
Pictures, how hard, price?
As mentioned, very easy Jim...here you can see the stock plug and the PC plugs and from there I routed them and the controller into the center console out of sight.
New Shoes Today!
  • Like 3
Used my truck as a truck! Went and got my girlfriend a Honda Metropolitan scooter, it was about 40 miles away and didn't feel like riding this thing 40 miles LOL, it's just for fun so we'll see how long the newness lasts!
12 hours ago, 9aj9 said:
New Shoes Today!
Something about your truck that just catches the eye...simple, clean and the silver and black with just the right amount of chrome. Very nice :thumbs:
THANKS! May look at doing the body colored side mirror covers....
ive got the old set of wheels/tires in the back so truck is sitting a little nose up, [emoji38]
Got these in the mail today. I’ll paint the surround like I did on my lights now and I’m trying to talk the wife into letting me retrofit them with some Morimoto md2s 5.0’s. I want some laser beams. Lol!
What the wife don’t know won’t hurt her lol
40 minutes ago, sirooga said:
Wheel, tires, suspension...looks and feels like a truck now. aadd074bd8226aadaa699bd4e2e3b706.jpg
Wow, this is the exact setup I was looking at!  17" Icon rebounds with coilovers.  What size tires did you go with?
What suspension setup did you use?
Edited by BbyDgital
It's the stage 5 Large Taper setup from Icon.
71555C - Front coilovers
78601DJ - Upper Control arms
77700C - Rear
I also had a 2" rear block added to keep some rake since I tow and don't like to squat.
The tires are 285-70-17 Ridge Grapplers 10 ply.
Night and day difference from the rough country leveling kit that I had before this.
Already done. Lol.
5 hours ago, SuperAllTerrain said:
On 2/11/2019 at 3:48 PM, Ravenkeeper said:
Let my wife drive my truck, for the first time today, since I took her CR-V to be serviced today.
She had to go to work and take our son to school, at the same time as the appointment.  I stole it back from her, after I took her to lunch.
May want to check the pressures on your shocks. Icon over charges them and the seals blow. At less that was my experience with my 71555c’s I had. A couple of shocks rebuilders even recommended to drop them down to 220 psi of nitrogen.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
