34 minutes ago, Ravenkeeper said:
Last night, I drove my wife to a new restaurant in Quartz Hill, CA, they opened their doors on Valentine's Day.
Fitting ... do you own that restaurant? LOL :smash:
Wasn’t today - but I went to the park to take a couple pictures. Here is probably my favorite.
  • Like 5
NO, unfortunately.  But the owner saw my truck sitting in the parking lot, and loved it.  She talked to my wife, about my plates, while I was in the bathroom.
..LOL, me too!
  • Like 4
46 minutes ago, STRMTRPR said:
..LOL, me too!
Info on how you mounted your license plate please :) Great shot and I love your True North emblems
.. I just removed the stock plate bracket (riveted on) and mounted a clear universal plate bracket from Amazon to the plastic trim on the bumper.. I will be installing a curved LED bar between the tow hooks when the weather warms up
10 hours ago, STRMTRPR said:
..LOL, me too!
Where you there to roof rake the sh!tter?  EH if not did you report that to the Royal ?? Mounties to come do it? Cause that looks like a collapse waiting to happen. ???
  • Haha 2
Those are pretty slick, just wish they would come on automatically when the running lights do. That's the only reason I'm not going this route, other than that, I really dig them...
I agree 100%, it would be really nice to have a way to hook up a wired relay in your car to trigger the bluetooth ON function (or even better, plug into your obd).  My BIL and I are looking into options.
Anyone know how much or where to get Bilstein 6112's for our Silverado's / Sierra's? I reached out to Bilstein today and they said that they are out but I am having no luck finding a place to purchase. Kit # 47-273702 is what I found on their website for out application
The one website i saw with them had them listed for $590 for just the front struts (no rear shocks). The whole Eibach kit which includes rear shocks is $586 at autoanything.
Waterfowler 41’s Youtube channel: https://www.youtube.com/user/brittmork
Yea i noticed it was front only which makes Eibach more appealing. I can get the Eibach kit on Jegs.com for like $536 and they wont charge me tax like Autoanything.
They dragged their feet so long on getting the 6112’s out you think they’d be a little more cost competitive to the Eibach kit, is basically the same set up. Unless the Bils kit is made of unobtanium or gold...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
