Got line x for the first time in this truck. Worth every penny. I love it. I also have a rubber liner to keep stuff from sliding around.
Do they have to put that line-x emblem in the bed?
Also is it required that they put the yellow sticker on the back of your truck so everyone knows you have a Line X?
Edited by Doobs41378
Also it required that they put the yellow sticker on the back of your truck so everyone knows you have a Line X?
Lol. I don't know how I feel yet about the badge in the back. I'm leaning towards seeing if I can skip it and save them a few bucks. ;)
Tell them before they start not to put the sticker on the window. I didn't get the badge or sticker. I bet someone is gonna tell you the warranty will be voided if you don't have the badge installed lol
lol, the sticker i'm not as worried about, since i can just remove it whenever. but the badge is there forever.
My front is 35 1/2 inches and the rear is a little over 39 1/4.
My front is 40 inches at the bottom the of black fender trim, rear is 40.5 inches
Are you talking about the Line-X badge that's actually in the coating? If so I would ask for them not use it. Decides i thought most places used the emblem that they spray over anyways.
Sent from my SM-G930V using Tapatalk
yeah, the actual line-x badge that's in the coating. do they still add that or is there a new way they get free advertising?
i think this is the updated logo right?
I believe it all depends on your dealer.
Yeah, i'm sure you're right. I've read that it might just be held on by some silicone that can be heated up and removed. I'll check it out when I get mine done.
got my zone 1.5 BL via UPS today...going to install next week. Should be a nice compliment to my 2 inch level in the front : )
too bad its winter here in new York and my stock 265-70-17s is what will be on it until spring time : /
delete
Edited by krzyd
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
