Chemical guys stuff is awesome, i did a full detain on mine, claybared with some swirl remover, whitelight, jetseal, and white wax and it turned out amazing.
Sent from my SM-G935V using Tapatalk
Awesome man! Next time apply jet seal first before the white light sealant , if you didn't already. [emoji1303]
Thanks man!
It's amazing. Finally had a chance to take it off road a couple weeks back and man was it fun. Suspension had plenty of travel and held up great. Towards the end of the day I changed the damping from full soft to about 5-7 clicks and it was way better for off roading at higher speeds. Worth the money for sure. Best thing I have done to the truck.
Love that youre actually offroading with appropriate tires and not a pavement princess with 24" wheels.
What air damn is that?
It's actually the "Oh Damn" model! Only installed on vehicles that promotes bundles of fun.
Sent from my SM-G930V using Tapatalk
Yeah I hear that, I didn't spend all that money to never use it for what its meant for haha.
OEM air damn has been removed and replaced with a soon to be released 2 piece skidplate made by a local off road shop that does all the work on my truck. SDHQ in Gilbert, AZ.
lol! yep!
lol! yep!
Can you talk them into coming up with something like this for the 14-15? My wallet is waiting.
11pm; everyone is asleep; and the notion struck. Just went out and did the 10-22 fogs with parking lights mod. Almost can't wait to get up and go to work just to see the lights running automatically! (It's dark when I leave for work. I know they don't run in the daytime.)
New hub assembly's both sides.
Battery failed. So that too.
Oil change.
New radio. ea90608c90bb977a66276cfbde0deba2.jpgb3277c39f2508af84c428d22efeebed2.jpgb6458980829ca8677cc1cb05ddd52319.gif
Sent from my Pixel XL using Tapatalk
looks good. are those RB-10 running broads ??
Bought some DL3 mirrors for it. Missed the power folding and signals that I had on my old truck.
are they plug and play or some reprograming from dealer ??? I miss the power fold -car washes .
Just need the mirrors, correct power folding switch and pgamboa on here sells the harnesses to make everything plug and play. Other wise you have to pin out the harness and add wiring for the signals and puddle lamps to work. A lot more work to do it that way.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
