Installed tow hooks and chrome skid plate. 2017 HD hood at the paint shop.
Ya know...never really been one for lowered trucks, but yours is quite sexy. Just cinched up that wheel gap
Looking good! I didn't realize the HD hoot fit on 1500's. Any special work to make it fit? Also how's the interior looking? I know some guys install a center console and bucket seats.
Sent from my SM-G930V using Tapatalk
I would also like to hear more about the hood swap. I like the HD hoods!
Thanks. Not exactly sure what all has to be done yet I have the paint shop doing the work but I will let you know once it is done. I got the idea from someone in fb. Yes I have the wireless charging center console installed I plan on getting leather soon.
  • Like 5
Thank you.
Cleaned my windows, and mirrors with Mother's California Gold liquid chrome polish. Best window cleaner ever.
Why did the reverse leds come on with the left flasher?
Bad camera angle for the left turn. These LEDs look so much better in person, hard to capture with iPhone camera.
The bar is actually 3 separate LED strips, so if I have it in reverse, my foot on the break, and turn signal on, you'll see the reverse light, turn signal, and brake light on all at the same time.
Edited by ChevyRoofer
@15 seconds the reverse leds flash with the left side, but not the right side. Just curious.
Edited by cbrsilv15
Went out and checked just now and you're absolutely right. The white LED turns on with only the left turn signal.
Guess I'll email Putco and see what's up.
Added the Curt-T trailer harness & Putco Switchblade 60" LED Tailgate Bar.
https://youtu.be/Zv6XvfEatCg
So just got off the horn with Putco customer service.
Apparently this error occurs with the LED taillights. Putco has a different product w/ a separate individual red wire for LED taillights.
92009-60 is the correct part number. So I'll be returning mine and getting the correct one. Thanks CBR!
Sweet. Glad they have something that will work.
Just one of those things you would probably never notice unless someone pointed it out. Lol.
Got my Go Rhino RB10 steps installed today.
4a7ac9116f23a37622ecf68245a7e107.jpgb844120c698ca4fa20d12cb69c8b71f9.jpg8f55f0e8679b986cd701e2e3b0a862ad.jpg21ed812d953dcdbeb030d5dbe592436d.jpgf8560c26132632cbb31385a1db0346e4.jpg7aab80011ed567859aca8d2cd6c69014.jpg
  • Like 3
looks good
looks good
Thanks. Was easier than I expected.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
