She got a bath. I also added a headrest monitor over my daughter's rear facing car seat.
Sent from my Pixel XL using Tapatalk. My build thread: http://www.gm-trucks.com/forums/topic/192614-tenscourts-2016-ltzz71-ccsb-4wd-silverado/
Absolutely love the our way iridium trucks looks so many different colors depending on lighting...and time between washes
Sent from my SM-G920W8 using Tapatalk
You my friend, have very unique use cases with your stuff. First, a camera routed as an input to your custom MVI radio. Then, a headrest monitor mounted on the front of the headrest? Genius! Love your use cases!
  • Like 3
Wheel and rim specs please. Leveled?
www.customwheeloffset.com/wheel-offset-gallery/167726/2017-chevrolet-silverado-1500-moto-metal-mo962-rancho-leveling-kit
Sent from my LG-H810 using Tapatalk
What is the order of the revamp?
Removed shell, sold it , debadged, tinted windows, drop shackle, intake exhaust , color match grill, leveling kit wheels tires
Looks way better IMO. Drop shackle?
Sent from my Nexus 6 using Tapatalk
I Revamped the look of the truck quite a bit in 3 weeks.
Looks great! What size grids are those?
Sent from my SM-G930V using Tapatalk
Thanks !
17x8.5!
Very happy with the turn out!
Changed out the front diff fluid. It was a nice grey milky fluid and I only got 1qt and 8oz out. Put 1qt and 24oz back in before it started to run out the fill hole. So it seems it was under serviced.
C4CAD501-B9EA-4E10-8BE4-3D6D79ED31F4_zps
4F95BA04-650D-4F39-B07F-F07F5D2268B9_zps
I also serviced the T case. It took just about 2 full qts before it started running out as well. It is so easy to do. Might just do it once a year.
1D0F6C2F-6CAC-4841-8BA4-291974A44C81_zps
C10B14C2-4293-4100-891B-011ED72B0400_zps
I didn't get to the rear. I didn't do my home work to find out it has a reusable gasket. So I'll get it some time this week while the weather is warm.
I did put it on my lift and I think it is a wee bit to heavy. I did manage to get the wheels off the ground but the lift didn't want to move very fast so I didn't push it. Just enough clearance to get under it while it sat level to service everything.
Thanks !
17x8.5!
I have a fresh set sitting in my garage! 17x8.5s. d15b18552fe3fd6fba507ea2e1a34452.jpg
Waiting on my tires and time to install my 5100s
  • Like 4
right on bro !! Can't wait to see pics !
Changed out the front diff fluid. It was a nice grey milky fluid and I only got 1qt and 8oz out. Put 1qt and 24oz back in before it started to run out the fill hole. So it seems it was under serviced.C4CAD501-B9EA-4E10-8BE4-3D6D79ED31F4_zps4F95BA04-650D-4F39-B07F-F07F5D2268B9_zps
I also serviced the T case. It took just about 2 full qts before it started running out as well. It is so easy to do. Might just do it once a year.1D0F6C2F-6CAC-4841-8BA4-291974A44C81_zpsC10B14C2-4293-4100-891B-011ED72B0400_zps
I've never done the front/rear differential, transfer case, or transmission. Is it fairly easy process on these vehicles? I'd like to do my own, as the dealer pricing is a small fortune.
Just curious, how many miles on those fluids ?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
