Yup, no problem. It fits perfectly in the gap between the tailgate and the bumper. I tapped into the 7 pin trailer harness that way its on a separate circuit than the led taillights. Ill shoot a daytime closeup photo if you want. Or I can pm you.
I'd love to see too
What do you guys think? Still waiting on the black 5.3 emblems to come in
Looks great! Adding it to the bucket list
Did that originally come on your vehicle and you just removed to paint or did you add that? I thought just the caddy suvs came with it.
Finally got my truck the husky liners and i love the fit. Amazon prime for $88 for 2 front ones - $50 discount for getting the amazon cc and take away shipping with BIGTHANKS promo code plus $5off from "MileUp" app. Paid $35 with tax and received them super quick :)
  • Like 8
Sent from my LG-H810 using Tapatalk
looks good. I order mine , just to pick a color for a Black truck ???
I don't know man, I have a white truck and painted mine the factory iridium metallic. I feel like a white engine cover will get to dirty and look crappy after a little while. Looks good at first tho lol. The iridium would be sweet for your black truck too
No it did not and yes it is for a Cadillac. I just replaced the emblem.
I upgraded my LT Headlights with LTZ ones. As expected, got hyper flash, so.....
I built set of PnP Headlight Harnesses with inline resistors (Gen5DIY equivalent).
Removed Grill and Headlights
Removed Headlight Trim Bezel using dental floss trick to prep for painting. My truck is Black - LOL
Resistors mounted on driver's sidewall.
Off to the paint shop they go.
All back together for now.
  • Like 7
Slick !!!!! Those harnesses you made look awesome too !! Professional !
Thanks! Try to be like Factory or better!
I built set of PnP Headlight Harnesses with inline resistors (Gen5DIY equivalent). 89b81ec19426273ef2fb619c7129186b.jpg
Removed Headlight Trim Bezel using dental floss trick to prep for painting. My truck is Black - LOLf8dd80fedf6e8c186238ed42025bad95.jpg
Sweet! I think you should change you name
" The Wire Whisper" ..... lol
  • Like 3
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,355 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
