That one looks different, not 100% sure it would fit. The only other harness I saw was the one going up into the console itself. I didn't check those wires though.
Sent from my SM-G930V using Tapatalk
y
Ok thanks ! But mine looks a little different than yours
y
Oh wow! Didn't know they changed in the '16 model. Cool. You can definitely add some more stuff then.
It's different because that's what it looks like for a full console. The previous picture is from a jump seat.
My baby is just a week old but I tore the door panels off, rewired the doors with new wiring harnesses to support the tow mirrors and slammed those mirrors on. Also modded the wiring so that the flood lights on the tow mirrors come on with both the cargo button and also when I put it in reverse.
  • Like 5
Looks sharp... Info on the cap?
Yessir, built to order Leer cap model 100XR. Added full "windoors" instead of the sliders. Upgraded LED interior light & carpeted interior. Sliding front window. Painted to match the truck
Here you go..its a OEM part, I like to use them when possiable. GM part # 15248604 ...picked it new up off eBay.
That fit your 1500 just fine?
Hmm I wonder if you can just plug this into the empty slot in the junction box above the spare tire !
That would be way too easy
I love your truck.....Are those the rims that came stock with it?
Yup, no problem. It fits perfectly in the gap between the tailgate and the bumper. I tapped into the 7 pin trailer harness that way its on a separate circuit than the led taillights. Ill shoot a daytime closeup photo if you want. Or I can pm you.
That would be awesome
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
