I've never done the front/rear differential, transfer case, or transmission. Is it fairly easy process on these vehicles? I'd like to do my own, as the dealer pricing is a small fortune.
Very simple! Just want to make sure you can remove the fill plug before you drain it
Goes with anything like that though, always make sure you can replace the fluids before you drain, no matter what your servicing !
Sent from my SM-G930V using Tapatalk
Yes, I always make sure I can remove the fill plug. Just because it is new doesn't mean it will be easy to remove. The process is easy, just get a pump for your qt bottles so you can pump the fluid into the diffs and T case. You can pick up a pump at Advance Auto, O'Riley's, Auto Zone or others.
Changed out the front diff fluid. It was a nice grey milky fluid and I only got 1qt and 8oz out. Put 1qt and 24oz back in before it started to run out the fill hole. So it seems it was under serviced.
C4CAD501-B9EA-4E10-8BE4-3D6D79ED31F4_zps
4F95BA04-650D-4F39-B07F-F07F5D2268B9_zps
I also serviced the T case. It took just about 2 full qts before it started running out as well. It is so easy to do. Might just do it once a year.
1D0F6C2F-6CAC-4841-8BA4-291974A44C81_zps
C10B14C2-4293-4100-891B-011ED72B0400_zps
I didn't get to the rear. I didn't do my home work to find out it has a reusable gasket. So I'll get it some time this week while the weather is warm.
I did put it on my lift and I think it is a wee bit to heavy. I did manage to get the wheels off the ground but the lift didn't want to move very fast so I didn't push it. Just enough clearance to get under it while it sat level to service everything.
I use my Flo-N-Go on my Diff's.
I use this thing to suck the fluid out of everything anymore. Lawn Tractors / Mowers ..
But it works great in the Diff's and transfer cases as well. Take everything out through the fill plugs.
Just have to work the hose in and down that's the only trick.
It connects to the shop Vacuum.
There are other product like it but this thing is cheap.
Any tutorial videos out there for these trucks on changing fluids? I wouldn't mind watching the process to familiarize myself better..
Been busy this past week.
Airaid intake tube with KN filter.
20170228 091558
Built a relay box with five switches
20170228 091549
Westin contour bullbar with 30in light bar
20170228 091608
LED bed lights (fit perfectly on the rails of the tonneau cover)
20170228 091641
  • Like 5
love that bull bar!!!...
looking at this one myself....
http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=38859
i looked at that one too. went with the westin contour because it doesnt make the front of the truck look to bulky like some bars and i got a smoking deal on it. the light bar is a totron 30in curved. super bright and good quality, was only $150 when i got it but i think the price has gone up
I second that , or maybe third it! I had never thought of a bull bar on my truck , but maybe! Looks like a state trooper push bar almost, nice.
Okay. Who was this? This is perfect. Lol. a4765d26751484be83605bee758f8b75.jpg
Sent from my Pixel XL using Tapatalk
That's great! Last year I tried to get NoBallz for my Ninja 300 but the DMV in Alabama denied it during thier final review.
Installed tow hooks and chrome skid plate. 2017 HD hood at the paint shop.
  • Like 6
Looking good! I didn't realize the HD hoot fit on 1500's. Any special work to make it fit? Also how's the interior looking? I know some guys install a center console and bucket seats.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
