Got the emblems in today and still deciding where to put them. Which one should I do? 597792887a1473d28d97dffb1cab61e2.jpg1ca49868e53449ede8a495d85016b061.jpg
Sent from my LG-H810 using Tapatalk
I like it on the front. What color is the cover?
I like the side ones! Looks good man. I did the OEM z71 on the side. [emoji1303]3dcc165d4704d33f68b7db047726fea2.jpg
Looks great. What GMC emblem are you using and what color did you paint it?
Installed my Corsa exhaust and rear bilstein 5100s. Only thing left to do now is fronts, mount tire and wheels!
The corsa sounds awesome. Little loud cold start, the neighbors will have to get over it...usually leave at 5am hah. Install went well, under 2hrs bymyself for both not including clean up time. Got the stock exhaust out in one piece.
Sent from my SM-G930V using Tapatalk
  • Like 8
Thanks! The GMC emblem is a factory part from a GMC terrain engine cover. I got it from the local dealer for like $15. It's an exact replacement to the caddy one. The paint color is a factory match GMC iridium metallic from scratch wizard. The z71 emblem is also an OEM part.
Thanks for the info. Any chance you have the part no. for the GMC emblem or the year Terrain it came from. Want to be sure if got enough info for the dealer to go on.
I believe it's a 2015 terrain.
Edited by Abearclaw
Who snatched this up? I missed out!
All done for now. Tomorrow I will be smoking out the tail lights and third brake light.
is 12643295 a good part number, there's multiple 6.2 cover numbers. And no reason why it wouldn't fit a 17 right?
6e7ce1482c2c1715a7683a62730c2955.jpgare those the needed studs??
4e914f4d545576990623b0f41d04f0d0.jpgcorrect order? I don't think I need studs though
Looks like you have the studs already[emoji1360] and yes the cover will fit a '17. You should be good to go man
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
