That actually looks pretty good. One thing you could do is leave the canopy the colour that it is, but add a bit of accenting to your truck of the same colour. Could use some vinyl decalling could look sharp! I added some matte black vinyl to my Tungsten Metallic to offset it a bit and it turned out good.
Sorry, but I think that would look horrible. Different shades of black/grey/silver are one thing, clashing shades of brown/tan are another.
Perhaps I would think it might look good if I did it, but I'm really not willing to spend cash on something that I think would likely look bad, at least to me.
Decided to try 2 thin coats of plasti-dip on the taillights. I am not a fan of the chrome bezels inside the light but my last resort is opening the taillights and plasti-dipping the chrome.
BEFORE
AFTER
Edited by AllTerrainX
BEFORE
AFTER
Thought of adding some Plastidip glossifier to it?
My truck is Matte Black so I dont like glossy :)
How does the light come through? Heard it looks blurry.
Edited by gary.smedley
I just noticed you have the nerf bars from GM I ordered and am having installed tomorrow. How do you like them? Any issues with them with rust or anything? They seem solid.
washed and waxed on this beautiful day
Looks great Zrodie??
I like them. Solid bars. No rust yet (knock on wood). I only have 16xx miles on it. I stored the truck this winter to keep the salt off.I have seen some other steps just like mine but there is a third section that is just below the front of the bed, so you can get easy access. That one would have been nice :)
Ya I have seen those. N-Fab and Rough Country have wheel to wheel nerf bars. I figure I've got the steps on the rear bumper so I don't really need the side ones too. Plus the GM ones you have look thicker with wider steps. I've heard complaints with the other ones that it's awkward to get out of the truck due to their placement.
Anyways, thanks again for the info. They look good on your truck and can't wait to get mine on tomorrow!
Painted my bow tie today. Turned out a lot better than I thought it would.
70f8f8c3de32d672e46ad22df612d405.jpg8c30fbebdf67c2dc05de181dae50654c.jpg279ed7661e245651f9b1c5cf34f794a0.jpg
  • Like 6
Lighting looks fine, in daylight and night. The only thing i dont like is at night, when the lights are on and if you were right up to it, you can see it is spotty. But from a far its fine.
I'd hate to remove the plastidip with only 2 coats. Would be a pain.
If I decide to remove the 2 coats and if its hard to remove, I'll prolly just put on a full coat or two and I'll remove it then. It's really easy to remove it when its fully coated.
Added rear foot lighting.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
