Used the $100 Online Bonus Coupon to pick me up a truck bed web and Center Console organizer, out the door for $10 with the coupon, not bad!
I wish you well with that system, I've seen many who have them on cars with bad results regarding scratches and such.
I'm set for my road trip.
Sent from my LG-H820 using Tapatalk
This looks like it will give you lots of protection. Do you encounter non-paved roads or is this more for bug protection? I remember driving the Alaska Highway in a new truck (before it was paved). It made my new truck look old really fast!
In my experience those leather car bra's do more damage than good. Yes they'll protect against paint chips and debris coming at your car. But they'll trap dirt and road grime between the paint and bra and then scratch the hell out of your paint. Your better option would be to clear vinyl wrap the front end.
Sent from my SM-G930V using Tapatalk
I will be taking it off after my trip and I do plan to install the clear bra during my transfer leave the end of this month along with the under coat for the chassis.
No more chrome.
Pamaguin, what are you using to black out everything, including the lower chrome trim piece above the valance?
Swapped my amazon led bar for a better one and added some pods. Its insane how much light they put out. I do a lot of driving in the country and on my properties, plus these will help a lot when we head to Big Bend this year.post-154045-149161411535_thumb.jpgpost-154045-149161412613_thumb.jpg
Sent from my SM-G935V using Tapatalk
Looks great!
Thanks. I was gonna get red/white/blue but thought it would be too much. Def looks good on Chevy bowtie.
Edited by gary.smedley
Wonder if I can get a Canadian flag bowtie :lol: I'm sure they are out there. But with no red/white on my truck it would look out of place I think.
Edited by SilveradoSaver
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
